Yes LE-v8 final is coming soon, will work on it after is released and also when a bug fix release is out too like 8.1 etc
Dont you worry about it
- Demetris
- Thread is marked as Resolved.
My English is not very good.
Thank you so much for your great work
IPTV Simple Client I can not install it on my M8 or my MXIII 2/8
Any manual like add original command in my mxIII? Thank youThank you
Am building LE-8.0 RC1 so just have some patience
maybe you get lucky on this one.
Am building LE-8.0 RC1 so just have some patiencemaybe you get lucky on this one.
Thank you
Builds LE-8.0 RC1 are now up in OP.
Enjoy! -
Hello,
can you tell me please which tool should I use to burn this image to Beelink S82 (2MB/8G)? I tried Amlogic USB Burning Tool (v. 2.0.7.2 and also older one), but when I try to open the image I get always error message - Parse burning iamage fail.
Thank you
Tomas -
Hello,can you tell me please which tool should I use to burn this image to Beelink S82 (2MB/8G)? I tried Amlogic USB Burning Tool (v. 2.0.7.2 and also older one), but when I try to open the image I get always error message - Parse burning iamage fail.
Thank you
Tomas
I 2nd this I too would like to a complete clean install instead of using the . update method I prefer to install via USB and recovery method thanks -
Great build can i use s82 for minix x8h? Or do i need a special build?
Hi I have updated my t8 box a few days ago to beta4 and was all working ok now I've tried to update to the latest build but I'm stuck on the boot screen can anyone help plz
Just installed the latest beta on my mxiii-1gb s802. Looks and feel are great! I am unable to install pvr addons ( i am using kodi for tv viewing) and there are no deinterlace options to be made (greyed out). As my tv source is 1080i, could (perhaps some fancy temporal) is deinterlacing possible on s802, does the gpu support this in hardware?
Thanks for the hard work!!
Hi I have updated my t8 box a few days ago to beta4 and was all working ok now I've tried to update to the latest build but I'm stuck on the boot screen can anyone help plzSent from my iPhone using Tapatalk
Me to on my mxiii 2G
I'm busy reinstalling the android firmware img with I put on my ad card with win disk image program if it works I will try the image latest image this way I'll let u guys know how it goes
Looks like there is something wrong with my latest images, i will remove them for now until i find some time to release a fixed version, sorry guys i have been busy with lakka lately and i didnt realize that images were unbootable on S802
If you guys dont mind would you please try the new lakka images on your devices to let me know if lakka is bootable on you
Index of /
Thanks -
Hi thanks for the reply I've got my box running on beta 4 now so all is good, can I ask what is Lakka and is it a newer version of krypton?
Hi thanks for the reply I've got my box running on beta 4 now so all is good, can I ask what is Lakka and is it a newer version of krypton?Sent from my iPhone using Tapatalk
Sorry but this build won't boot either this and the other version seem to update the boot loader I think something isn't right and that's maybe why it won't boot properly?
What will not boot? Are you talking about lakka?
Στάλθηκε από το GT-I9300 μου χρησιμοποιώντας Tapatalk
Wich on did you use? I have the MXIII 2G as well. Running the beta4 perfecly.
Not working is blocked at startup and you have to install the original firmware with usb burning
mxIII 2/8 beta4 work fine
Thank you for your work -
I havent got time to even remove the RC release so guys patience i have to compile LE again switch from lakka to it and test, if all ok this time will release a working rom.
