Hi Demetris and other helpful libreelec friends,
I am getting the error "to prevent automatic repair attempt continuing press any key or power off your system within the next 120 seconds" when i try to install the latest LibreELEC-S8X2.arm-8.0.1-M8.img.gz file. This is on my S802 M8 with the roundish remote. BTW RC4 also fails.
I am installing from android and i have cleared cache and data after a clean android install.
I've also tried to unzip LibreELEC-S8X2.arm-8.0.1-M8.zip and install that way but it just boots back to android. (it seems to be missing a file)
lastly, i installed Openelec and other libreelec builds (which do install fine) but i am not able to get the .nocompat file to the update folder when i SSH "touch /storage/.update/.nocompat" to use the .tar file you provided.
Do i have some bad memory cards or can this issue be caused by something else?
thank you so much for your help again.
