I compiled new images will push when i find free time
Edit:Uploading
Demetris -
December 7, 2016 at 10:38 PM -
Thread is Resolved
Thanks demetris!!!now ok on MXIII 2G
One thing I noticed with RC3 on my M8, is that while RC2 dropped down to a faster 2.4 GHz connection, RC3 stays on 5GHz even when the signal is of very low strength.
I'll probably fix it on the router side, but it was just something that caught my eye.
(as far as I know there is also no way to force LE to use a specific WiFi band) -
I would need a log from you on rc2 & rc3 while you use your wifi to pinpoint the issue.
Demetris I must thank you again, you have given this old box a new lease of life
Thank you
Paul
Sent from my SM-G930F using Tapatalk
I'll see if there is anything showing in the logs on this (and if the updated build does the same).
Thanks. -
Sorry to bug you demetris but I was wondering if you had a .tar for 7.0.3 for m8 as when I click the Jarvis link in op it tells me I don't have permission to view, if I click on the krypton link it shows the 7.0.3 folder but only has 2 files for the s82.
Many thanks and all the best
Paul
EDITED: Also just to let you know my remote is working again in the updated RC3. Thank you
You are not bothering me at all.
When i started with le source, v8 stable was far away so i took what was available and i just bring it up2date with then 7.0.3 stable on my device(S82) but you can take those sources link in OP
and compile yourself a version for your device as for me that version is EOL and wont bother again. -
I did try compiling once, yeah didn't go to plan hahahaha.
Tbh 8 is rocking so I'm probably going stay on it for a while.
The only issue I have come across so far
On RC2 for m8 when I pressed power button on remote I got the shutdown menu. On RC3 it just powers the box off with no menu but I also can't "wake" it back up with out flicking the switch, this doesn't bother me in the slightest as I always turn it off at the switch any way, just thought I'd let you know.
Again thank youPaul
I know what is causing that and will be fixed maybe in next version.
Hmm will have a look.
Edit:Fixed
Will I need to reinstall le then transfer over my remote.conf ?
Pretty sure demetris knows the remotes are not working being as avd told him and then he replied with fixed, my advice go back down to rc2 or wait for an update to be pushedSent from my SM-G930F using Tapatalk
Is your stock remote working.? -
Back on new RC3 and 5Ghz speed is also much better again. (acceptable at 52 Mbps and not much less than the 64 on 2.4).
No idea what happened there, but at least it's no issue anymore -
New RC3 only change is the remote configuration fixed
Installed rc3 yesterday is that been updated since then?
Is your remote working?
No I installed le then transferred remote.conf to storage>configuration but still doesn't work.
Update with new RC3 then
Oh right you have updated them today. Thanks. Will I need to do a new install or can I update?
