  • i've tried setting the locale in the /storage/.profile which now looks like this:
    export LC_ALL="en_US.UTF-8"
    export LANG=en_US.UTF-8
    export LANGUAGE=en_US.UTF-8
    Typing locale now gives me these results:
    Unfortunately, i still get the same error when starting emulationstation
    terminate called after throwing an instance of 'std::runtime_error'
      what():  locale::facet::_S_create_c_locale name not valid
    Aborted
    Aborted
    That didn't work...tried it also...There is an addon in Libreelec repo just for that called Locale
    I can confirm that this beta works on generic and Rpi 3.
    Thanks.
  • Glad it worked for you too..also doesn't have to be en_US.UTF-8 only...mine worked on en_GB.UTF-8
    I cant even install locale from libreelec repo.
    It just says installation failed.
    other libreelec repo addons allow me to install (chrome for example) just locale gives me installation failed :(
    Edited 2 times, last by robmcc83 (October 19, 2019 at 12:03 PM).
  • hi guys.
    what kind of machine do i need to use play! (ps2) and dolphin(gamecube) emulators?
    i've tried on a nuc (Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz), with 4GB memory.
    play! - games are unplayable
    gamecube - there is an annoying freeze every 30-40 seconds.
    tried the same games on a friends yoga380 (i5, 8 gb ram). dolphin runs ok (no freezes at all), play! is still laggy.
    other cores (atari800, snes, ppsspp etc ) work fine.
    also, what's more important for the emulation (cpu/gpu/mem)?
  • Hello,
    I have migrate my librelec to 9.2 on rpi4.
    Retroarch work fine.
    But emulationstation don't work ...
    I have this log :
    lvl2:     EmulationStation - v2.0.1a, built Jan 24 2017 - 15:30:02
    lvl2:     Creating surface...
    lvl0:     Error creating SDL window!
        Could not create GLES window surface
    lvl0:     Renderer failed to initialize!
    lvl0:     Window failed to initialize!
    Any idea ?
    Regards
  • Are you running LE on 4k resolution?
  • yes of course. On LE 9.0.2 ES work fine.
    After update to 9.2 I have this error.
    Just tried mine tonight just in case after updating to 9.2 yesterday and it's working fine..I m on version 8.201.1...Rpi2
    Try to force update all addons and rename the ES userdata folder and try again after a restart..
    \\LIBREELEC\Storage\.kodi\userdata\addon_data\game.emulationstation
    Also since LE9.1.xx ES needs Locale addon to work from LE repo..set Locale to your location example en_GB>UTF-8
