Hello.
Thanks in advance for supporting old ARM boxes!
I installed LE 11.0.6 (meson-gxl-s905x-p212.dtb) on my old X96 box (ARM S905X). Everything works fine, but I have a problem with the sound. The SPDIF output does not work at all, the external audio out has a very weak sound. HDMI audio is fine. The audio settings show - audio output device - ALSA: S905X-P212.
I tried to install LE 9.2.8 (gxl_p212_1g.dtb), the sound works correctly there. Everything works, HDMI, external audio out and SPDIF. In the settings there is - audio output device - ALSA: AML-M8AUDIO.
Is it possible to solve this problem somehow?
Thank you Popmar
