Hi,
this is my first post, thank you in advance for any help or support.
I bought a Raspberry Pi 5 to upgrade from Rpi4 that is already running on LibreELEC, but, I'm a noob, I realized that there is no 3.5mm audio output on the Rpi5 .
On Rpi4 I use that output for music playback using the audio profiles add-on.
My question is, if I buy an USB audio interface (i.e. https://www.amazon.it/dp/B08Y8CZB2S?ref=emc_p_m_5_i_atc but this is just an example), something simple that do not requires drivers, will I be able to use it on Rpi5 running on LibreELEC to output music, also using the audio profiles add on?
And if so, how do I enable the sound card?
