Hi
Using the generic LE 12 nightlies on my HTPC (AsRock Beebox J3160) with a universal remote (XBMC-profil).
The remote is working out of the box since years with the standard XBMC profile from the remote code library
With the update to LE12 20231127 (and all versions after this release) the remote is not working anymore. No keypress is recognized.
Tested on two (identical) HTPC's.
Tested all other related available codes on the remote (XBMC, xbox) also.
Reverting back to LE12 20231125 (last working version) brings back the full function.
Remote is Philips SRP5016
Had ordered a new version of this remote (hardware v02) with a new/actual code library, but also no function.
Additionally: A standard OrigenAE RC197 Remote (RC6) is still working with the versions 20231127 upwards.
Any chance to solve this?
Shall I provide a log?
