USB Flash Drive Not Mounting In /var/media
  • Thanks, that worked.
    (I ran chkdsk about a month ago when having issues on my other Linux machine, though failed to think that was the issue with the RaspberryPi. Something I'm learning and will be more aware of in the future).
    Out of curiosity, what line/(timestamp?) in the link pasted above pointed you to the error? Something for me to remember.
  • Code
    [   14.878121] ntfs3: sda1: failed to replay log file. Can't mount rw!
    In 99/100 cases when a "Windows" flavoured filesystem is being used and either won't mount or goes read-only, chkdsk.exe is the answer.
