Does not work with my TV
  • Don't have it. The only USB thing I had was a Logitech keyboard combo, with the USB dongle plugged in and the keyboard possibly was out of range (in another room).
    This USB dongle works, and it's a different USB device:
    Aug 27 07:07:41.909466 LibreELEC kernel: usb 6-2: new full-speed USB device number 2 using xhci_hcd
    Aug 27 07:07:41.910568 LibreELEC kernel: logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-2/input2
    Aug 27 07:07:41.910732 LibreELEC kernel: input: Logitech K400 as /devices/pci0000:00/0000:00:1c.0/0000:01:00.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input5
    Aug 27 07:07:41.911690 LibreELEC kernel: logitech-hidpp-device 0003:046D:400E.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-0000:01:00.0-2/input2:1
    Aug 27 07:07:41.911847 LibreELEC kernel: input: Logitech M570 as /devices/pci0000:00/0000:00:1c.0/0000:01:00.0/usb6/6-2/6-2:1.2/0003:046D:C52B.0003/0003:046D:1028.0005/input/input6
    Aug 27 07:07:41.912801 LibreELEC kernel: logitech-hidpp-device 0003:046D:1028.0005: input,hidraw2: USB HID v1.11 Mouse [Logitech M570] on usb-0000:01:00.0-2/input2:2
  • I think your PC has a hardware defect, which results in no audio:
    Aug 27 07:07:41.913375 LibreELEC kernel: Unstable clock detected, switching default tracing clock to "global"
                                             If you want to keep using the local clock, then add:
                                               "trace_clock=local"
                                             on the kernel command line
    Aug 27 07:07:41.913479 LibreELEC kernel: ALSA device list:
    Aug 27 07:07:41.913584 LibreELEC kernel:   No soundcards found.
                                               "trace_clock=local"
    OK, I'll check it out.
    Interestingly, Zotac proudly claimed the existance of "FREE Media Center OS for your ZBOX mini-PC". I could not find that OpenELEC release, nor how to install it (in simple way). Maybe you could help with that, and I'll try? Ma our
  • http://ftp.sunet.se/mirror/archive…media/openelec/ <= OE v4-v6
    https://mirror.math.princeton.edu/pub/openelec/ <= OE v7-8
    ^ 10 seconds of Google searching found some old OE mirrors that still have files for download. You can probably get something to install and show the Kodi home-screen, but when it refuses to access anything on the internet due to expired TLS certs and other issues that impact on old software, there will be zero support in this forum. We forked from OE in 2016 and anything before LE is not our problem.
    NB: The OE v8 release is after we forked LE and it has a ton of problems due to a large number of changes being added without any prior testing (one of the several reasons we forked) .. so best to skip that one.
