[RPi4] Argon One Case Shutdown
  • I don't see any related errors at the log. Maybe you should create another one, because logging was just activate during that session.
    Ok, I did that, I restarted it several times, here it is:
    External Content pastebin.com
  • Thanks for the log.
    • Login by SSH, and use the poweroff command. Does that work correctly?
    • I've seen a Bluetooth error at the log. Not sure whether it's relevant, but disable Bluetooth, and try again.
  • myshit ,
    You will need some additional scripts that are part of the Argon Pi addon. Since the add-on was no longer maintained after the initial commit on GitHub, I ported it myself to make it work with LibreElec 10+ two years ago. I haven't touched this since then, but it still works with LibreElec 11 and you can also configure the fan speed.
    I'd have to look up the git repo and installation package. If my newly created user allows this at all, I could make it available here.
    That sounds really good. If I could also control the fan speed it would be a nice bonus since this doesn't work too (but since the CPU load is not usually very high, the passive "cooler" (case) handles ut). So, you're saying, that it could resolve the full shutdown problem? If you would be so kind and post the repo and some instructions with it i would really appreciate it.
    Yes, the poweroff command is working ok via SSH. I don't think that bluetooth is has something in coincidence with it
  • Yes, the poweroff command is working ok via SSH. I don't think that bluetooth is has something in coincidence with it
    So shutting down from GUI hangs, but shutting down from SSH works as expected.
    Both tested without the Argon One case. Are those statements correct?
    If yes, then I'll ping the devs to have a look.
  • Please be aware:
    I'm not a developer of KODI Add-ons. This is only a result of someone who had the wish to get the add-on work again with LibreELEC 10 and later.
    Argon ONE Control
    2025/04/23 Version 1.1.11 (recommended): Please note the updated documentation.
    What it does:
    Provides a GUI and installs a service to manage Argon ONE case features including the power button, fan speed, and the Argon IR remote.
    • supports LibreELEC 10 / 11 / 12 / 13
    • supports Argon ONE V1/2 (RPi4)
    • supports Argon ONE V3 (RPi5)
    • enables IR Receiver (V2/V3, or if self added to V1 pcb)
    • enables Argon REMOTE support (rc_maps + keymap)
    • fan control with fan curves CPU, SSD/NVMe, GPU and PMIC
    • graceful shutdown (power button commands: Reboot , Shutdown ...)
    :!:For full support of the power button commands with a RPi5, please use LE12 at least.
    It includes a workaround for the lgpio bug (Many thanks to HiassofT). Also thanks to Nekromantik who gave me feedback regarding LE12 nightly and testing with the new V3 case.
    Important: The add-on download has been moved to GitHub: Download Please use the latest version of the add-on to ensure that the known bugs have been fixed.
    For historical reasons only: If someone stays on LE10 and the last versions really don't work, they can try version v0.0.4. I have left the download of the outdated version as an attachment just for this case.
    Known Issues:
    :!:After the power button at remote control or the button (held for > 3 seconds, but < 5 seconds) on the back of the case was pressed, KODI including all OS processes only has ~10 seconds to shutdown properly! Once initiated, the 10 seconds power cut timeout can't be interrupted and is perhaps only with another case firmware correctable.
    Solution:
    To compensate that, the add-on has been repeatedly optimized to decrease the shutdown time to below 8 seconds. Depending whats currently installed and running in KODI it need sometimes longer, then the shutdown will not be graceful and data corruption is possible in the worst case.
    This behaviour only occurs if you use the power button on the remote control or on the back of the case to switch off. If the KODI power menu is used to switch off, the power cut will triggered at the very end (+10 seconds).
    Argon ONE V1 / Fan HAT with early MCU firmware versions:
    There are some reports on the Argon40 forum that the fan control scripts they provide no longer work with the Argon ONE V1 cases since the new command set with register support was added for the Argon ONE V3 cases. I cannot verify this, and there is no feedback on whether this is really the case and switching off the register detection definitely helps. A compatibility mode was therefore added in version 1.1.9, which explicitly deactivates the detection of register support. If you are one of the early adopters with a V1 case (with micro HDMI outputs at the back of the case) and the fan control or the shutdown process already isn't working right:
    • Enable "Activate compatibility mode for ONE V1"
    • Shutdown KODI/LibreELEC
    • Make sure that the case is powerless (unplug PSU) for some seconds
    • Start LibreELEC with compatibility mode enabled
    Another workaround for the following scenario:
    Remote control power button pressed → 10 seconds timer starts -> shutdown is initiated → red LED turns off, but it seems that it doesn't respond to the power button on the remote to get it on again.
    Please try in this situation (unsuccessful shutdown):
    • The red LED must be off
    • Press the power button on the remote control
    • Wait 10 seconds (MCU cuts off power internally)
    • Press the power button on the remote control again to boot
    Breaking change:
    :!:Additional I have switched from lircd to rc_maps/keymaps (thanks to adam.h. for providing the files). If you use a self made remote control profile for your remote control, please make a backup of your remote control configuration and/or place a lock file before installation to prevent overwriting:
    touch /storage/.config/argon40_rc.lock
    Source:
    The original sources are from there: GitHub Argon40Tech and here: Installation package version 0.0.1
    I have forked (26.10.2023) the Argon40 add-on repository and pushed my changes to this repository: GitHub Argon ONE Control
    Installation:
    Quick installation (available for LE12 / LE13)
    Search for "Argon ONE control" within the LibreELEC add-ons section below "Program add-ons" and install the add-on. All requirements will be downloaded and installed automatically. If you install this add-on the first time, a reboot is required afterwards to activate all interfaces like I2C, UART and IR.
    Please have a look for more details at the linked documentation, especially if you have already an older version of the add-on in use.
    Manual installation
    The installation process will try to add 3 lines to the config.txt to enable the needed modules for I2C and UART. This part is not bullet proofed, because it looks only for the first line. It skips the needed modification if the line "dtparam=i2c=on" is already there.
    A few things to do:
    • Upload one of the linked zip files (GitHub release asset: libreelec_argononecontrol_x.x.x.zip) to /tmp, /storage or another place where you have access via KODI
    • Allow installation of Add-ons from external sources:
      Enable "Settings->System->Addons->Unknown sources"
    • in the main menu within Add-ons select "Install from ZIP file", confirm the security question and browse to the folder where you uploaded the zip
    • select the ZIP file and press OK
    • after installation: Ignore the "Device Configuration Error" teaser message and reboot, so that the modules for UART and I2C are activated
    Within Add-ons list, the Argon ONE Control (fka: ArgonForty Device Configuration) add-on should be available now. There you can configure the fan settings and the shutdown should work properly now. Please be patient, it will take a few seconds for the LED to goes off.
    Important: Recent versions are available at GitHub first, followed by publishing via LibreELEC add-ons repo: Download
  • So shutting down from GUI hangs, but shutting down from SSH works as expected.
    It shutdowns ok with SSH or from GUI. The only thing is the red LED that still keeps turned on preveting me from turn the Rpi again back on after shutdown - I have to manually press the button for few seconds.
  • It shutdowns ok with SSH or from GUI. The only thing is the red LED that still keeps turned on preveting me from turn the Rpi again back on after shutdown - I have to manually press the button for few seconds.
    I see. Then the shutdown actually doesn't work as expected, because the red LED stays on.
    The cause of such issues is often a file system with errors. Broken file systems can't be unmounted at shutdown. If you only use the microSD for files, then install LE from scratch, or use a repair tool for checking / repairing.
  • Hi Da Flex ,
    I hope I can remind me right, because these information are 2 years old... ;)
    There are at least 2-3 revisions of the Argon One case. The newer ones even have an infrared receiver on board. The power-on button is not directly connected to the Pi. In between is a circuit board with a microcontroller. This is responsible for switching off the power supply to the Raspberry after shutting down. The microcontroller recognizes the signal at the power-on button and can also trigger a RESET (different PIN on the Raspberry) by pressing the power-on button twice in quick succession. If you press this button longer than 3x seconds, the Raspberry will be shut down and the power will be switched off after a delay. It may be that this behavior depends on the firmware version of the microcontroller and could be different with the first batch of the casing.
    If you shut down the Raspberry via OS, the microcontroller in the Argon One lacks the information that its allowed to cut the power supply. Therefore, after an orderly shutdown, the red LED at the front, behind the semi-transparent plastic cover, remains on. However, the microcontroller also knows a return channel via PIN on the UART interface. This PIN changes its logic level after shut down of the Pi and the microcontroller starts the process to cut the power of the Raspberry Pi. This has to be configured specifically on every OS and with every startup. It's part of the ArgonForty Device Configuration add-on, for example. Alternatively, there are some other scripts/daemons that do something similar.
    I have a feeling, you want something what's never existed.
    I have 3 RPi's and using with LE for years. And the red LED after shutdown always remains on, and to start again always needs to do a power cycle. That is how the RPi works with LE. It's not like a "normal" PC, with stand-by part in power source and with IO chip always powered, ready to react if the power button is pressed (and with a hidden power consumption in stand-by...).
    The RPi have only a single GPIO input able to force to boot again if is activated with a button.
    If you have concerns about the "LED red light", I think that LED can be disabled in config.txt.
    If you have concerns about power consumption, after RPi "shutdown", the most part it's the power source itself (like any phone charger, have some consumption even if no phone connected), so switching of the main power can be the solution.
  • That does the trick :) the red LED turns off after shutdown command from GUI (I didn't test it with SSH), I can turn Rpi back on after that and the fan control also works. All of that is working under LE 11.0.3 version. I want to thank you very much for the solution as well as I want to thank everyone else for their answers, what a great community, I've never seen that before ^^
  • myshit,
    You're welcome. Nice to read that it's working for you now.
    Da Flex
    I have reviewed the python scripts again. To be technical correct I should revise my posting (#28)
    • the microcontroller supports Reboot (double-tab at power-on button) and not RESET
    • the microcontroller signals 2 different requests (Reboot, Shutdown) at PIN7 of the Pi4 board
    • during shutting down a script sends 2 messages at SMBus (i2C) back to the microcontroller
      - first message : stop fan
      - second message: initiate power off, cut when the serial pin goes 'down'
      More information about this are available here: https://github.com/Argon40Tech/Argon40case
    These things are only working if a service is running in the background to make cycling checks at PIN7 for new message from the microcontroller. The shutdown script is a hook during the LibreELEC OS shutdown: https://wiki.libreelec.tv/configuration/startup-shutdown
  • I'm late but give my 5 cents anyways. ^^
    I'm actually doing "both" what's discussed here by the press on a MCE remote with the kind help of an IR-Receiver/Blaster.
    So in the end I always have AC power cut (no standby power) but also have LE shut down properly before cutting the power. To turn my home theater ON or OFF is just one button on the remote and the IR-Receiver/Blaster orchestrates the rest (Turning the AC Plug On, send signals to Screen, Amp, LE Box to turn on or vice versa with proper delay for LE to shut down completely. I don't use/need any scripts in LE for this to work.
  • Add-On was update to version 0.0.7.
    Thanks for maintaining this addon its great.
    Using a V3 case with an LE12 nightly and addon v0.0.7, the fan pulses every 20-30 seconds. Is this expected behavior? LE is reporting temps of about 42c and fan thresholds are the default.
  • Using a V3 case with an LE12 nightly and addon v0.0.7, the fan pulses every 20-30 seconds. Is this expected behavior?
    If the on/off frequency of the fan is pretty constant, then I would say it's expected behavior. My power LED (always-on expected) had random on/off cycles without that fix.
  • PANiCnz ,
    your are the second which reports this behavior with Argon One V3 in combination with 0.0.7. So there seems really to be an issue within the current code.
    Currently I can't reproduce with my V2 case... it could takes longer to find the root cause.
    As long the CPU temperatur is below the first threshold, the fan should be off. Pulsing is possible if the current temperature is around the threshold. 42c is far away from the 55c default value. I fear I have possibly insert this bug as I switched over to the Argon Register Helper methods, which has a mechanism included to differentiate the firmware versions.
    From the testing with Argon V3 case exists a version 0.0.6d, but this version should only be used with LE12 + Argon One V3 cases, because the commands were changed for the new firmware. I don't know if there are also V2 cases with this type of firmware in the wild.
    Edit: This bug was fixed beginning with v.0.0.8. Please update to a current version of the add-on.
    Edited 2 times, last by HarryH (February 23, 2024 at 7:05 AM).
