  • WiFi is little green board above label "DJ1018KP". In original KII Pro this board is Ampack AP6335. Chip on this board is Broadcom BCM 4335. Try to submit command:
    udevadm info /sys/bus/sdio/devices/sdio*
    For AP6335 is SDIO_ID=02d0:4335
  • [font][font]Ciao [/font][/font]
    [font][font]Sto installando libreelec 8.0.1 do Una microSD [/font][/font]
    [font][font]Ho bisogno della lima dtb.img di Kii. [/font][/font]
    [font][font]Qualcuno ha capito?[/font][/font]
    Edited once, last by pioppo (April 30, 2017 at 6:55 PM).
    it is giving me error once i ssh login into putty on Windows.
    can you guide me in detail pls so that i can provide what you are asking me and get help from you.
  • it is giving me error once i ssh login into putty on Windows.
    command is ok, dont forget to put * in the end, or simply copy paste whole command
  • command is ok, dont forget to put * in the end, or simply copy paste whole command
    This is what i am getting once i input this command through SSH in Putty
    Quote
    LibreELEC:~ # udevadm info /sys/bus/sdio/devices/sdio*
    Unknown device, --name=, --path=, or absolute path in /dev/ or /sys expected.
    LibreELEC:~ #
  • plikmuny Your WiFi chip is not properly loaded by the driver in LE, this command will only show something relevant in Android (for now).
    Sent from my Nexus 4 using Tapatalk
    How to load it properly ? Pls guide me to get it working. Thanks
    Any Linux experts here to help me get my WiFi working ?
    Edited once, last by plikmuny (May 1, 2017 at 9:15 AM).
  • Driver fails to identify your WiFi chip voltage, I don't know how to fix it yet. Please provide us information about your WiFi chip from Android or from an earlier LE build where it works so we can have a point to start from.
  • Hmm... i need some time to provide you the necessary info you need for my Problem.
    Thanks for responding. I will come back with logs, give me some time.
    But one thing i have to tell you, LE 8.0.1.i version is super smooth and responsive. Thanks for that.
  • Hello,
    I have KI Plus with DVB-T2 tuner only and internal tuner does not work with tvheadend=tvheadend does not see TV adapters (but works with Android). External tuners are ok with tvheadend. Can anybody help me fix this, please?
    Thx, Martin
    Libreelec dmesg shows:
    [ 8.982102@0] aml_dvb_init: aml dvb init
    [ 8.982289@0] aml_dvb_probe: probe amlogic dvb driver
    [ 8.982307@0] aml_dvb_probe: dmx rst ctl = ffffffc022f63c80
    [ 8.982315@0] aml_dvb_probe: asyncfifo rst ctl = ffffffc022f63940
    [ 8.982321@0] aml_dvb_probe: ahbarb0 rst ctl = ffffffc02347d980
    [ 8.982328@0] aml_dvb_probe: uparsertop rst ctl = ffffffc02347d940
    [ 8.982337@0] aml_dvb_probe: ts0: parallel
    [ 8.982401@0] aml_dvb_probe: ts0_control: 0x0
    [ 8.982408@0] dvbdev: DVB: registering new adapter (amlogic-dvb)
    [ 8.982412@0] aml_dvb_probe: Registered adpter: amlogic-dvb
    [ 8.982835@0] aml_dvb_dmx_init: demux0
    [ 8.983256@0] aml_dvb_dmx_init: demux1
    [ 8.983642@0] aml_dvb_dmx_init: demux2
    [ 8.983753@0] aml_dvb_asyncfifo_init: af:0 irq:51
    [ 8.983773@0] DMX: async fifo 0 buf size 524288, flush size 262144
    [ 8.983804@0] aml_dvb_asyncfifo_init: af:1 irq:57
    [ 8.983820@0] DMX: async fifo 1 buf size 524288, flush size 262144
    [ 9.009102@0] DVB FE: Init AVL6862 frontend 0
    [ 9.899749@0] i2c i2c-1: avl6862: i2c rd failed=-11 len=4
    [ 9.899753@0] i2c i2c-1: avl6862: attach failed reading id
    [ 9.899767@0] DVB FE: avl6862_attach attach failed!!!
    Android dmesg shows:
    [ 2.646967@3] aml dvb init
    [ 2.647030@3] DVB: probe amlogic dvb driver
    [ 2.647043@3] DVB: dmx rst ctl = ffffffc02285dcc0
    [ 2.647049@3] DVB: asyncfifo rst ctl = ffffffc02285dbc0
    [ 2.647055@3] DVB: ahbarb0 rst ctl = ffffffc02285dac0
    [ 2.647060@3] DVB: uparsertop rst ctl = ffffffc02285d9c0
    [ 2.647069@3] DVB: ts0: parallel
    [ 2.647135@3] DVB: ts0_control: 0x0
    [ 2.647141@3] DVB: registering new adapter (amlogic-dvb)
    [ 2.647737@3] DVB: demux init
    [ 2.648188@3] DVB: demux init
    [ 2.648588@3] DVB: demux init
    Edited once, last by bisak (May 1, 2017 at 9:22 PM).
  • Hi Kszaq: i tried to switch on WiFi network in Android, but it simply fails... i dont know why. i think there is some hardware connection problem with my wifi card. Now i know where my problem is. it just fails to turn on no matter how many times you click on it.
    Is there a way how i can repair it ? anyone know how to do it here ? what could be a solution for my problem ?
    I am really pissed off by this. Any clue pls... thanks in advance
  • anyone noticed lipsync problem on live tv, im on latest image now kii, with recommended tvh + pvr versions, as far as i tested today version 8.0.0c was fine, -i version with same addons, lipsync appears after a while of watching, its not channel related cause its happening randomly on sd / hd channels.
    Same for me.
  • No LipSync problems on my side (Kii Pro + DVB-S)
    But my TVHeadend42 8.1.114 starts only in 2/10 system starts. I have to deactivate and activate the Addon manually. Even a start delay of 3 seconds doesn't help
    Can someone plz tell me how to identify the problem? Which log do i have to activate and what do i have to look for?
    BTW Great work afl1. The system gets better and better! THX
  • Same for me.
    I know about possible lipsync issue. I am testing fix for it.
    If you running from SD card, try to use another SD card.
    Try to upgrade to LibreELEC repository TVHeadend42 8.1.111. There is lower version but newer revision.
    Edited once, last by afl1 (May 2, 2017 at 2:04 PM).
  • Hi, fantastic work.
    When i'm watching tv with tvheadend and i use (for example, but is the same in others menus) the epg and the video is in background, the audio and the video des-sincronize.
    Is it normal? how can I solve this?
    Edit: I can see that I have Lipsync issue, as other people. And afl1 is testing fix for it. Thanks.
    Edited once, last by ferfoxi (May 2, 2017 at 11:06 AM).
