  • Hi all,
    Afl1 => i tested DVB-S scan with your beta N1 with new drivers and your version of TVheadend : 7.95.beta5N1 and i still got problems for scanning with theses transponders on Astra 19.2.
    Anyway apart this problem TVheadend & Oscam run fine :)
  • Hi all,
    Same result at me.
    Failed transponders with non zero services were scanned with external tuner. Failed transponders with 0 are not possible to scan (week signal, wrong or changed parameters for transponder etc.).
  • Same result at me.
    I am scanning on 28.2 and was updating libreelec then trying to scan dvb-s2 again and getting failed on everything,
    Ive just deleted the "network" under dvb inputs
    Created a new network for 28.2 and then forced scanned again and so far have picked up 100 services from 9 out 109 muxes
    Dont know if this might help anybody as my DVB-S scanning in, ill update later to let you if the whole scan worked
  • I had never problem to descramble tvheadend stream with oscam. You are only (except beginners) who has descrambling issue now. You probably need tvheadend + oscam tutorial.
  • Is it possible to backup the satellite frequency/transponder data between firmware updates ?
    Yes!
    Settings -> LibreELEC -> System -> Create System and Kodi Backup
    once completed copy the .tar file from samba sharing to PC
    .tar include the tvheadened configuration files:
    /storage/.kodi/userdata/addon_data/service.tvheadened42
    copy it back to this folder for new version software and then install tvheadend42
    The simplest upgrade:
    - create new SD card;
    - from new card copy kernel.img and SYSTEM to the old one.
    All config and installation is preserved. If addons are not started upgrade them from repository or zip.
    Edited once, last by afl1 (February 12, 2017 at 10:40 PM).
  • I update from 5n to latest built (update over old 5n, no new install), but now I missed the dvb-s and the external dvb-t don't work anymore. I must perform I fresh install? I can't update the old one?
    PS: I put the update file with external dvb-t inserted...
    Edited once, last by Alessio78 (February 12, 2017 at 10:47 PM).
    I use tvh/oscam with full success already minimum 2 years long (I buy wetek play, when it announced).
    I never had problem with descrambling. I make 4-5 times full reinstall, without problems.
    I maked tvheadend plus oscam with my synology nas too, just for experiment, and with my laptop (libreelec) without problems.
    Now with the same settings
    TVHeadend K1Plus-> local OSCAM : not working
    (I tried 2 method set up oscam from beginning, and copy from wetek userdata all oscam settings)
    TVHeadend K1Plus -> local OSCAM the 7.0.2.004.4 version : working
    TVHeadend K1Plus-> OSCAM on NAS : working
    TVHeadend Wetek Play -> Wetek's Oscam: working
    Heres is k1plus oscam log (not work):
    • 2017/02/13 06:01:27 1292EB3D c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0653 ECM_PID: 1868 PROVID: 000000
    • 2017/02/13 06:01:27 1292EB3D c (dvbapi) Demuxer 0 ecmpid 1 CAID: 0D97 ECM_PID: 173C PROVID: 000000
    • 2017/02/13 06:01:27 1292EB3D c (dvbapi) Demuxer 0 ecmpid 2 CAID: 0B02 ECM_PID: 14E4 PROVID: 000000
    • 2017/02/13 06:01:27 1292EB3D c (dvbapi) Demuxer 0 ecmpid 3 CAID: 1815 ECM_PID: 13B8 PROVID: 000000
    • 2017/02/13 06:01:27 1292EB3D c (dvbapi) Demuxer 0 found 4 ECMpids and 1 STREAMpids in caPMT
    • 2017/02/13 06:01:27 1292EB3D c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0D97 PROVID 000000 ECMPID 173C ANY CHID PMTPID 0000 VPID 01C3
    • 2017/02/13 06:01:30 1292EB3D c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 3 disabled ecmpids!
    • n2017/02/13 06:01:30 1292EB3D c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0D97 PROVID 000000 ECMPID 173C ANY CHID PMTPID 0000 VPID 01C3
    • 2017/02/13 06:01:33 1292EB3D c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 3 disabled ecmpids!
    Heres is k1plus with synology oscam log (work):
    • 2017/02/13 06:04:50 626E8D86 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0653 ECM_PID: 1868 PROVID: 000000
    • 2017/02/13 06:04:50 626E8D86 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 0D97 ECM_PID: 173C PROVID: 000000
    • 2017/02/13 06:04:50 626E8D86 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 0B02 ECM_PID: 14E4 PROVID: 000000
    • 2017/02/13 06:04:50 626E8D86 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 1815 ECM_PID: 13B8 PROVID: 000000
    • 2017/02/13 06:04:50 626E8D86 c (dvbapi) Demuxer 0 found 4 ECMpids and 1 STREAMpids in caPMT
    • 2017/02/13 06:04:50 626E8D86 c (dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 1
    • 2017/02/13 06:04:50 626E8D86 c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0D97 PROVID 000000 ECMPID 173C ANY CHID PMTPID 0000 VPID 01C3
    • 2017/02/13 06:04:52 626E8D86 c (dvbapi) Demuxer 0 found 4 ECMpids and 2 STREAMpids in PMT
    • 2017/02/13 06:04:52 626E8D86 c (ecm) anonymous ([CAID:0D97] [PID:000004] [SID:7664] [L:B8]): found (187 ms) by Reader-1
    • 2i017/02/13 06:04:55 626E8D86 c (ecm) anonymous ([CAID:0D97] [PID:000004] [SID:7664] [L:B8]): found (187 ms) by Reader-1
    And another observation: i tried with 7.0.2.004.4 and its working too with k1plus, only the new le8 beta has problems
    Edited once, last by envagyok (February 13, 2017 at 6:38 AM).
  • Thanks afl1 for the new version => works for me and the Signal quality & SNR works now :). And same problems as before no RMC Decouverte on astra (can't scan). It's time for find DVB-S2 usb tuner for scanning ...
  • Hi.
    I see there is communication tvheadend + oscam, but there is no reader able to descramble ecmpid. What kind of reader are you using?
    Here is a log from beta6:
    You can use scan made by E22TVH tool. In following input.zip is scan for Hotbird 13.0E, Astra 19.2E and Astra 23.5E.
    in /storage/.kodi/userdata/addon_data/service.tvheadend42/ replace input folder with input from zip file. To preserve current scanning you can rename it input0 and then unzip file. Then you have to restart tvheadend. After restart you can see 3 new networks: DVB-S 130E, DVB-S 192E and DVB-S 235E, than you have to connect new networks to Tv Adapter (LNB).
    And finally map channels.
    Edited once, last by afl1 (February 13, 2017 at 9:36 AM).
