I have an i5 12400 with 16 GB RAM, there runs le11 nightly from 18.01.2023. Basically, almost everything works, except for the 3D mode, if I want to watch a 3D movie in 2D, then the double image remains. And I can't find the other modes anymore, like deinterlaced or magenta blue.
3D Movie in 2D Problem
Voosjey -
January 20, 2023 at 12:44 PM -
If it was working under older LE Generic releases you will prob. need to use the Generic-Legacy (X11) image as Generic now runs GBM which probably has no 3D support.
Will there be 3D support? It would be a pity if the legacy expires, and then you can no longer watch all your 3D movies. At least it should be possible to integrate the two possibilities
1.3D in 2D
2. to be displayed like film
At the moment he gives me the possibilities. But they just don't work. I'll try the legacy now, but nevertheless these functions should also work with GBM
Most improvements to Intel and AMD drivers come from the vendors themselves. And because none of the TV manufacturers are creating new TVs with 3D capabilities now (the 3D fad has passed) there's no "business" demand for 3D features; only from end-user consumers who don't puchase silicon chips in volume quantities and so aren't important.
In the legacy version I can watch the 3d movies in 2d, but the HDR support is gone. I hope that at least the 2D support for 3D movies comes in GBM
I'm curious. What is the format of your 3d videos? e.g.
half-SBS
half-TAB
full-SBS
full-TAB
MVC
Half SBS, if I say at GBM he should display it as 2D, he still shows the double images, if I then turn off the 2D mode, I suddenly have 4 pictures next to each other.
is there any new information about when the 2D view will be repaired?
This problem was already visible on the rpi4 which has been using GBM a lot longer. If you search for 3d and rpi 4 you'll get several posts about it. I ignore the 3D gui and just play the SBS and TAB files like normal 1080p videos and set the 3d mode on my tv as a workaround.
If the problem now exists on the generic build as well I believe it's either time to fix it or to disable the 3d features on GBM builds (at least temporary).
I understand that 3D MVC support is a driver issue and unlikely to ever be fixed.
3D output to a TV (making it switch to the correct 3d mode automatically) might be difficult as well.
On the other hand half or full TAB or SBS should be relatively easy to fix for a developer that is familiar with the GBM pipeline (sadly, I am not a programmer). It is clear that the kodi gui has support for 3d features and asks a left and right view from the video pipeline, but GBM provides an unsplit frame twice instead of a frame split in a left and right view. That is why in 2D mode with your half SBS file, you get a split view, and in 3d mode you get 4 views. To fix this someone needs to implement the 3D part in GBM so it can deliver a left and right view separately when it knows the 3D format of the source file. That would fix all problems with (H)TAB and (H)SBS encoded files and give users the same working output options as with the legacy builds. It would not work for MVC encoded files.
I know it's very low priority so I will be patient and use the workaround like I have been using for the past years.
The fix is not done "in GBM" .. the fix is done in the RPi video driver, and the Intel driver, and the AMD driver, and the Amlogic driver, and the Rockchip driver, and the Allwinner driver. That's rather a lot of very complicated low-level driver work and the reason why it hasn't already been done and isn't likely to happen. The possibility of an RPi4 only fix is marginally higher, because at least one of the RPi Foundation devs has a personal interest in 3D support. However, progress probably requires him to have lots of rainy-days with low workload in the office or a long convalesence at home with too much free time and an itch to scratch; neither scenario is that likely.
If we are not speaking about MVC encoded 3D or framepacked output, I don't understand why we need driver support. A HSBS encoded file is just a normal 1080p file where both views are shown at half width. Output would again be a normal 1080p output with a split gui on top. Why does a video driver need to support it?
Meanwhile, omega is out, but the bug is still present in this version. Am I the only one who doesn't feel like converting all my 3D movies to 2D? It was so nice to say with Kodi, look in 2D and it was good.
chewitt That somehow doesn't sound right, but maybe it is.
Let me confirm:
- We have a video file which, by its metadata, is recognized as 3d.
- The file itself contains the two images in one of the common layouts, but is a plain video file apart from that.
- Based on the metadata, Kodi will automatically do "something" when the video starts.
- In my understanding, the only thing Kodi would actually have to do to make this usable (in a barebone form) is show the menu twice (depending on the format).
- Instead, and this might or might not be some driver problem, the full image gets duplicated.
So, even if the image duplication is a driver issue, there must be something that triggers this.
At the same time, I don't see what processing step exactly would be required that would trigger this, as "all we need" is the menu...
the menu is not needed, when you switch from 3D to 2D, only one image has to be seen, but it remains with the double image. and if you then switch back to the 3D view like in the movie, then it suddenly shows 4 images, so a switch works, it just doesn't switch it to 2D view
Hi all,
As others her, I have the problem of lack of 3d support by GDM or the associated graphic driver on RPi4.
For some time, I was able to use the workaround by de-activating the 3d in Kody and forcing the TV to switch to the appropriate 3d mode (SBS or Top-Down). The menus and subtitles were not displayed correctly but at least, I was able to watch 3d movies.
Unexpectedly, yesterday this workaround stopped to work and the 3d mode is now in gray in the TV menu. I am still able to make 3d work on some HSBS content via the Sony Player but I can no more watch 3d movies via Kodi ...
My TV is a Sony Bravia 2015 model.
Does anyone have an idea on how to make the 3d mode forcing work back ?
Unfortunately, switching from 3D to 2D still doesn't work in LE13. In which file is this controlled? I'm not a programmer, but maybe there's a way to fix it.
It works as soon as it has been quadrupled once, then you can switch from double to quadruple, as if the correct command is functioning too late. Instead of initially halving from 2 to 1, nothing happens at first, then when you switch back from 2D to 3D, the image appears doubled, and then you can switch happily. I hope I am understood.
StereoscopicsManager.cpp is the main control of what 3d mode is configured.
Some of the gui rendering code is in GraphicContext.cpp and some of the video playback rendering code is in VideoPlayerVideo.cpp
Have fun.
