Bluetooth pairing does not work
    I try to connect my bluetooth speaker to libreelec 10.0.2 (generic.x86_64), but it doesn't work.
    On my Beelink X55 is a Win10 partition, on that the speaker works fine. So Bluetooth is availabe.
    In Libreelec I enabled Bluetooth in the Libreelec general settings and after that I click on "Bluetooth". But it will only say "NO BLUETOOTH DEVICE FOUND. PLEASE PUT YOUR BLUETOOTH DEVICE INTO DISCOVERY MODE AND START THE SCAN".
    Yes, I put my device in Discovery mode, in Win10 I also managed it.
    my boompods did not connect either
    Am I missing something?
    Earnie
    addendum:
    Log
    2022-08-12 16:11:15.723 T:1236 ERROR <general>: SETTINGS: bluetooth.start_discovery # AttributeError("'NoneType' object has no attribute 'startswith'")
    2022-08-12 16:11:15.803 T:1236 ERROR <general>: SETTINGS: bluetooth.start_discovery
    *********************************** Unhandled exception detected ***********************************
    Diagnostic info
    Exception type : AttributeError
    Exception value : 'NoneType' object has no attribute 'startswith'
    System info : uname_result(system='Linux', node='BeeX55', release='5.10.76', version='#1 SMP Sat Mar 5 19:12:54 CET 2022', machine='x86_64', processor='')
    Python version : 3.8.9 (default, Mar 5 2022, 19:13:59) [GCC 10.2.0]
    Kodi version : 19.4 (19.4.0) Git:19.4-Matrix
    sys.argv : ['']
    sys.path:
    ['/usr/share/kodi/addons/service.libreelec.settings',
    '/storage/.kodi/addons/xbmc.python/lib',
    '/usr/lib/python38.zip',
    '/usr/lib/python3.8',
    '/usr/lib/python3.8/lib-dynload',
    '/usr/lib/python3.8/site-packages',
    '/usr/share/kodi/addons/service.libreelec.settings/resources/lib',
    '/usr/share/kodi/addons/service.libreelec.settings/resources/lib/modules']
    Stack Trace
    File:
    /usr/lib/python3.8/threading.py:890
    Code context:
    Local variables:
    self = <Thread(Thread-4, started daemon 139690246137408)>
    File:
    /usr/lib/python3.8/threading.py:932
    Code context:
    Local variables:
    File:
    /usr/lib/python3.8/threading.py:870
    Code context:
    Local variables:
    File:
    /usr/share/kodi/addons/service.libreelec.settings/resources/lib/oe.py:623
    Code context:
    Local variables:
    match = True
    File:
    /usr/share/kodi/addons/service.libreelec.settings/resources/lib/oeWindows.py:377
    Code context:
    Local variables:
    btn = 2
    controlID = 1000
    currentEntry = 4
    lastMenu = 4
    objList = <xbmcgui.ControlList object at 0x7f0c5027f8b0>
    selectedEntry = <xbmcgui.ListItem object at 0x7f0c505d7360>
    selectedMenuItem = <xbmcgui.ListItem object at 0x7f0c50886db0>
    self = <oeWindows.mainWindow object at 0x7f0c500cc740>
    strHoover = ''
    strMenuLoader = 'menu_connections'
    File:
    /usr/share/kodi/addons/service.libreelec.settings/resources/lib/log.py:69
    Code context:
    Local variables:
    arg = <xbmcgui.ListItem object at 0x7f0c50886db0>
    args = ( <bluetooth.bluetooth object at 0x7f0c449f8d60>,
    <xbmcgui.ListItem object at 0x7f0c50886db0>)
    function = <function bluetooth.menu_connections at 0x7f0c44a18f10>
    header = 'SETTINGS: bluetooth.menu_connections '
    kwargs = {}
    level = 0
    File:
    /usr/share/kodi/addons/service.libreelec.settings/resources/lib/modules/bluetooth.py:279
    Code context:
    Local variables:
    focusItem = <xbmcgui.ListItem object at 0x7f0c50886db0>
    self = <bluetooth.bluetooth object at 0x7f0c449f8d60>
    File:
    Code context:
    Local variables:
    arg = <bluetooth.bluetooth object at 0x7f0c449f8d60>
    args = (<bluetooth.bluetooth object at 0x7f0c449f8d60>,)
    e = AttributeError("'NoneType' object has no attribute 'startswith'")
    function = <function bluetooth.start_discovery at 0x7f0c44a160a0>
    header = 'SETTINGS: bluetooth.start_discovery '
    kwargs = {}
    level = 0
    outer_stack = [ FrameInfo(frame=<frame at 0x7f0c501695a0, file '/usr/lib/python3.8/threading.py', line 890, code _bootstrap>, filename='/usr/lib/python3.8/threading.py', lineno=890, function='_bootstrap', code_context=None, index=None),
    FrameInfo(frame=<frame at 0x7f0c50327580, file '/usr/lib/python3.8/threading.py', line 932, code _bootstrap_inner>, filename='/usr/lib/python3.8/threading.py', lineno=932, function='_bootstrap_inner', code_context=None, index=None),
    FrameInfo(frame=<frame at 0x7f0c50176f40, file '/usr/lib/python3.8/threading.py', line 870, code run>, filename='/usr/lib/python3.8/threading.py', lineno=870, function='run', code_context=None, index=None),
    FrameInfo(frame=<frame at 0x7f0c5047e8a0, file '/usr/share/kodi/addons/service.libreelec.settings/resources/lib/oe.py', line 623, code openConfigurationWindow>, filename='/usr/share/kodi/addons/service.libreelec.settings/resources/lib/oe.py', lineno=623, function='openConfigurationWindow', code_context=None, index=None),
    FrameInfo(frame=<frame at 0x7f0c5073a3b0, file '/usr/share/kodi/addons/service.libreelec.settings/resources/lib/oeWindows.py', line 377, code onFocus>, filename='/usr/share/kodi/addons/service.libreelec.settings/resources/lib/oeWindows.py', lineno=377, function='onFocus', code_context=None, index=None),
    FrameInfo(frame=<frame at 0x7f0c505df770, file '/usr/share/kodi/addons/service.libreelec.settings/resources/lib/log.py', line 69, code _log_function_2>, filename='/usr/share/kodi/addons/service.libreelec.settings/resources/lib/log.py', lineno=69, function='_log_function_2', code_context=None, index=None),
    FrameInfo(frame=<frame at 0x80e6680, file '/usr/share/kodi/addons/service.libreelec.settings/resources/lib/modules/bluetooth.py', line 279, code menu_connections>, filename='/usr/share/kodi/addons/service.libreelec.settings/resources/lib/modules/bluetooth.py', lineno=279, function='menu_connections', code_context=None, index=None)]
    File:
    /usr/share/kodi/addons/service.libreelec.settings/resources/lib/modules/bluetooth.py:138
    Code context:
    Local variables:
    File:
    /usr/share/kodi/addons/service.libreelec.settings/resources/lib/dbus_bluez.py:166
    Code context:
    Local variables:
    path = None
    File:
    /usr/share/kodi/addons/service.libreelec.settings/resources/lib/dbus_utils.py:106
    Code context:
    Local variables:
    args = ()
    bus_name = 'org.bluez'
    interface = 'org.bluez.Adapter1'
    kwargs = {}
    method_name = 'StartDiscovery'
    path = None
    File:
    /usr/lib/python3.8/site-packages/ravel.py:1643
    Code context:
    Local variables:
    self = <ravel.BusPeer.Object object at 0x7f0c50250320>
    timeout = -1
    File:
    /usr/lib/python3.8/site-packages/ravel.py:1388
    Code context:
    Local variables:
    destination = 'org.bluez'
    path = None
    self = <ravel.Connection object at 0x7f0c448c2e00>
    timeout = -1
    File:
    /usr/lib/python3.8/site-packages/ravel.py:1335
    Code context:
    Local variables:
    path = None
    timeout = -1
    File:
    /usr/lib/python3.8/site-packages/dbussy.py:5753
    Code context:
    Local variables:
    path = None
    File:
    /usr/lib/python3.8/site-packages/dbussy.py:5743
    Code context:
    Local variables:
    path = None
    ************************************* End of diagnostic info ***************************************
    2022-08-12 16:11:15.806 T:1236 ERROR <general>: SETTINGS: bluetooth.start_discovery
    Object info
    Object : <bluetooth.bluetooth object at 0x7f0c449f8d60>
    Object type : <class 'bluetooth.bluetooth'>
    Object attributes:
    BLUETOOTH_DAEMON = '/usr/lib/bluetooth/bluetoothd'
    D_OBEXD_ROOT = '/storage/downloads/'
    ENABLED = True
    OBEX_DAEMON = '/usr/lib/bluetooth/obexd'
    OBEX_ROOT = None
    bluez_agent = <bluetooth.Bluez_Agent object at 0x7f0c44b06100>
    bluez_listener = <bluetooth.Bluez_Listener object at 0x7f0c44b4af50>
    clear_list = <bound method bluetooth.clear_list of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    close_pinkey_window = <bound method bluetooth.close_pinkey_window of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    connect_device = <bound method bluetooth.connect_device of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    dbusBluezAdapter = None
    dbus_error_handler = <bound method bluetooth.dbus_error_handler of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    disable_device_standby = <bound method bluetooth.disable_device_standby of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    disconnect_device = <bound method bluetooth.disconnect_device of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    disconnect_device_by_path = <bound method bluetooth.disconnect_device_by_path of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    discover_devices = <bound method bluetooth.discover_devices of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    discovering = True
    do_init = <bound method bluetooth.do_init of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    enable_device_standby = <bound method bluetooth.enable_device_standby of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    exit = <bound method bluetooth.exit of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    find_adapter = <bound method bluetooth.find_adapter of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    found_devices = frozenset()
    get_devices = <bound method bluetooth.get_devices of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    init_adapter = <bound method bluetooth.init_adapter of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    init_device = <bound method bluetooth.init_device of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    listItems = {}
    menu = { '6': { 'InfoText': 704,
    'listTyp': 'btlist',
    'menuLoader': 'menu_connections',
    'name': 32331}}
    menu_connections = <bound method bluetooth.menu_connections of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    obex_agent = <bluetooth.Obex_Agent object at 0x7f0c44ec3b10>
    obex_listener = <bluetooth.Obex_Listener object at 0x7f0c44ec4ef0>
    oe = <module 'oe' from '/usr/share/kodi/addons/service.libreelec.settings/resources/lib/oe.pyc'>
    open_context_menu = <bound method bluetooth.open_context_menu of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    open_pinkey_window = <bound method bluetooth.open_pinkey_window of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    pair_device = <bound method bluetooth.pair_device of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    properties = { 0: {'type': 4, 'value': 'Paired'},
    1: {'type': 2, 'value': 'Adapter'},
    2: {'type': 4, 'value': 'Connected'},
    3: {'type': 2, 'value': 'Address'},
    5: {'type': 1, 'value': 'Class'},
    6: {'type': 4, 'value': 'Trusted'},
    7: {'type': 2, 'value': 'Icon'}}
    remove_device = <bound method bluetooth.remove_device of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    standby_devices = <bound method bluetooth.standby_devices of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    start_discovery = <bound method bluetooth.start_discovery of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    start_service = <bound method bluetooth.start_service of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    stop_discovery = <bound method bluetooth.stop_discovery of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    stop_service = <bound method bluetooth.stop_service of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    trust_connect_device = <bound method bluetooth.trust_connect_device of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    trust_device = <bound method bluetooth.trust_device of <bluetooth.bluetooth object at 0x7f0c449f8d60>>
    visible = True
    ************************************** End of object info ******************************************
    Edited once, last by earnie: missing log inserted (August 12, 2022 at 4:34 PM).
