You using Ethernet?
[rpi2 addon] moonlight wont launch
zosky  -
May 4, 2016 at 6:13 AM  -
You using Ethernet?Yes
Can you post your addon I'll try it on a chromebox.
- Official Post
SDL2 is built statically so it's now needed on the base version. The addon will run fine without a special build.
SDL2 is built statically so it's now needed on the base version. The addon will run fine without a special build.Did you try the generic version? Did the video decoding worked well?
- Official Post
I don't use windows so I can't actually test.
I've tested this on my chromebox. It loads, pairs and even connects but doesn't show any picture. Can post logs if needed. This was tested on CvH 7.0.0 build. The Rpi connected to the same windows machine fine.
I've tested this on my chromebox. It loads, pairs and even connects but doesn't show any picture. Can post logs if needed. This was tested on CvH 7.0.0 build. The Rpi connected to the same windows machine fine.Try disabling Force HW in the addon settings.
Finally got it to display. Disabling HW acceleration worked great. I did notice that a reboot is required for any settings that are changed to take effect. My dualshock 3 isn't working and no sound. IVe got the exact same settings on a Rpi in a different room where sound and controller work. I've got sysdefault in audio device and control mapping set to dualshock3. Any pointers. IVe not seen any lag or breakup of the display but that's based only on games loading and steam intro. THis was tested on LibreELEC CvH 7.0.1.
Edit: This machine does have retro arch installed if that makes any difference.
2nd Edit: With dualshock 3 selected the analogue stick seem to be mapped wrong. On FIFA up on the analogue stick sends the player running down and vice-versa.
Try this mapping for the dualshock3... script.moonlight/dualshock3alt.conf at ad01b129a5adb91f4207882085dad2797278e040 · dead/script.moonlight · GitHub
Not sure why sometimes the default dualshock3 works and sometimes it doesn't.
Please post the output of "aplay -l" -
LibreELEC:~ # aplay -l
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: ALC283 Analog [ALC283 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0Edit: Controller now works great, Just tested with FIFA
Take a look at this linux - What do ALSA devices like "hw:0,0" mean? How do I figure out which to use? - Super User
And in the addon "Audio Device" settings put "hw:0,0" -
Yes when the addon shows up in the repothank you !! works great
SDL2 is built statically so it's now needed on the base version. The addon will run fine without a special build.Does that mean it's possible to get this working on an OpenElec EGL build?
If so, that'll make the wife super happy
- Official Post
It should already be available in the Repo
It should already be available in the RepoI don't know how to add the LibreElec repo to Openelec (I can't seem to find the url). I'll be using the zip file found earlier in this thread.
*edit* the zip file doesn't work on Openelec.
I have the same issue as stConners even if i disable "Force HW" (and restart). It pairs, connects but didnt establish the stream.
System:
Asus chromebox with LibreELEC 7.0.2, Moonlight 7.0.101Log:
Moonlight Embedded 2.2.0 (SDL;VDPAU;PULSE;CEC)
Searching for server...
Connect to 192.168.1.2...
NVIDIA GeForce GTX 970, GFE 2.11.4.0 (protocol version 7)
SDL: could not create window - exitingAny idears?
