Problem installing nightly cubox imx6
  • Hello I have a cubox imx6 box that is stucked in 8.2.5. I have found that you have nightly build for this box version 11. I am downloading it and connecting via ssh to the box and place it at the .update folder then I reboot. The file is decompressed succesfully,checksum of kernel is fine and then I am getting the below error
    "Error in check update: mount_common: Could not mount /storage/.update/.tmp" , I have tried many nightly updates for this box and always getting the same error. Any suggestions ?
  • I have fuzzy memory that that the boot files/layout is different and thus you cannot update from LE 8.2.5 to LE10/LE11 images and it needs to be a clean install. As I'm the closest to a maintainer the iMX6 images have (and I didn't touch a Cubox-i in the last 6-months) I'd strongly suggest you test boot from an SD card first.
