I'm running the yesterday nightly
see the attached photo:
"Update Channel" pulls nothing in => so no "Available Versions"
it has been working moons ago
idea's ?
idea's ?
We upgraded the releases server the other day and that broke some of the plumbing behind the scenes of the update system. It will get fixed but you can also do a manual update by SSH'ing into the box and downloading (wget) files directly to /storage/.update/ then rebooting.
thanks chewitt for lightning fast support.
I know the update via ssh and realized the updates on the website.
Just a headup from here
is a kodi.log anyway needed
if so:
and I'll mark this thread as resolved ...
cause it's seem to be fixed with nightly from 4. or 6. march 2022
no idea, I'm running nightly only (can't compare)
all I can say the above IF error (comment #1) is fixed.
And I do see the URLError NOT the first time [1]
anyway:
nslookup releases.libreelec.tv
Server: 192.168.100.1
Address 1: 192.168.100.1 fritz.box
Address 1: 164.92.230.217
dito for test.libreelec.tv
so I guess
  it's not on my site here
cause when I open
https://164.92.230.217/releases.json
I see the content of releases.json
but when I do it with
http://164.92.230.217/releases.json
then I get "404 Not Found"
- no webserver expert here -
but don't they do redirect http requests to https at their own (somehow) ?
btw:
in releases.json there are hardcoded http://...
is this correct ?
[1]
even more :
I see them ~all~ the time
 , also - IIRC - when I was using LE release.
The eldest report I could find (24.01.2021) - with nightly, though -
ping CvH , $All
I'm thinking to move the "URLError Bug" to a new thread
comments/rottenfruits ?
P.S.
where is the best place ?
LE github or here ?
CvH is referring to 'Temporary failure in name resolution'
Feb 24 17:56:53.914844 LibreELEC systemd[1]: Wait on network was skipped because of a failed condition check (ConditionFileNotEmpty=/storage/.cache/libreelec/network_wait).
Feb 24 17:56:53.914992 LibreELEC systemd[1]: Reached target Network is Online.
Jan 24 22:46:02 LibreELEC systemd[1]: Condition check resulted in Wait on network being skipped.
Jan 24 22:46:02 LibreELEC systemd[1]: Reached target Network is Online.
	Wait on Network is disabled resulting in kodi starting without active network connection.
Ahhhjaaa,
switching "Wait on Network" to ON and the URLError is gone.
Thanks !
