I have tried without success, there are a number can you suggest a particular build?
failed to start xorg
surveyor81 -
January 13, 2022 at 5:53 PM -
How exactly does it fail with nightly? The latest nightly should work in theory. Kernel 5.16 does support Alder Lake CPUs.
The Build I tried was: orangepi-win and roc-pc-plus, the message was as above, ie.
failed to start xorg/is your GPU Supported? I an about to try pine-64
Trying Generic x86 would be a better idea.
ps. I have attached a screen shot of the error message:
Hi keka1234 please try the latest LibreELEC-Generic img.gz from https://test.libreelec.tv
just tried the latest Generic build however still have the same problem, again I have attached the screen shot
Problem Solved with the nightly generic build. The problem was the hard drive had a partition form an earlier version of Libreelec (10.01). I formatted the hard drive however did couldn't delete the partition using Windows.
Thanks for you help.
Thanks for confirming. I was pulling my beard out
Hi, solved the GPU problem however with the nightly builds now don't have the TV tuner drivers I had in Version 10.01? I assume these drivers are added when the nightly build goes to Stable version?
Dvb not included due to “kernel”compatibility during nightly. What driver are you using?
The TV Tuners are Hauppage HVR-2200. Currently when I access TVHeadend it doesn't recognise the tuners, LE 10.01 does.
The saa7164 module should be on the image
6.8. SAA7164 cards list — The Linux Kernel documentation
lspci -v
# check for the card and that the module is loaded
dmesg
# use modprobe to load the driver (if required)
modprobe saa7164
dmesg | paste and post the url that outputs
should be supported out of the box
Just ran the commands, TVHeadend still doesn't see the tuners. Also couldn't find reference to the card under lspci -v and dmesg
All Good it works and thanks again. Small hardware issue.
