Is it possible to export LibreElec-Setting to an USB-Stick ?
  • Question:
    Is there a simple way to export the settings of 10.0.1 directly to an USB-Stick and then import it back to a new Installation ?
    In Detail:
    I'm running 10.0.1 from an USB-Stick on my PC.
    Now I want to put a SSD inside my Computer an run in from there.
    So I want to export only the LibreElec-Settings from the USB-Stick Version directly to another USB-Stick,
    remove the LibreElec USB-Stick,
    install the SSD into the PC,
    make a fresh Install of LibreElec 10.0.1 on the SSD
    and then import the saved Settings from the USB-Stick into the LibreElec 10.0.1 Version installed on the SSD.
    Nothing will change except the Fact that LibreElec now will run on the same Computer from a SSD and not from an USB-Stick
    Edited once, last by Niceguy (January 8, 2022 at 4:13 PM).
  • I guess it should go like this:
    - create a backup [1] with LE config tool/addon on the stick
    - pull off the stick
    - install the ssd and on it LE
    - plug in the stick
    and now either
    - point in the LE config tool/addon the "backup restore" to the stick (should be /var/media/<something need to filled in>/....)
    or
    - copy the backup from the stick to the backup folder on the ssd (~/backup) and restore with LE config tool
    - reboot (to activate the restored settings/services)
    - check your setting
    - create a new backup (now on the ssd)
    The "I'm unsure -"part :
    - are there special folders for pics/movies/... ?
    I guess they should backup by hand (addon "system tools" => MC maybe via ssh'ed in OR with internal filebrowser)
    if you're running with special kernel boot parameter, e.g. i915 FW: needs adjustment by hand, caused ironed by the installer
    [1]
    backup contains:
    - ~/.cache with all it's content/settings
    - ~/.config with all it's content/settings
    - ~/.kodi with all it's content/settings (and I guess the setting for pic/movie libraries too, but not the pics/movies files itself)
    Specials:
    - if it's a used ssd you should think about secure erase the ssd *before* installing LE (usually with vendor tools)
    - if the usb stick is free now you should think about "long format" it under windows
    both to get them back to (nearly) initial speed
    - run "fstrim -va" via ssh for your ssd from time to time (weekly/monthly)
    Edited 2 times, last by GDPR-7 (January 8, 2022 at 5:26 PM).
    - plug in the stick
    Thanks for your Answer,
    but how do I "create a backup [1] with LE config tool/addon on the stick" ?
    Which Addon do I need ?
    I found a simple Solution:
    In the System (Settings)-Menu I go to
    LibreElec -> System -> Backup -> Create System and Kodi Backup and create a Backup-File
    This Backup is a *.Tar File, which is saved in the "Backup"-Folder
    Then I go to my Windows-PC, open the Windows-Explorer, select "Network" and it shows me my LibreElec-Installation.
    I go to the Backup-Folder and copy the Backup *.Tar-File onto my USB-Stick.
    Later, after I had installed the new Version on the SSD I simply copy the File back from the USB-Stick to the "Backup"-Folder, using the Windows-Explorer again.
    There is also a Solution where you use the LibreElec File manager, so you don't need another PC, just look here:
    And to the Recalbox-Developers:
    For me, a "Backup" is a way to restore my System when it had been crashed.
    A "Backup" is stored in a save Place (and not on the same Drive of the System you want to Backup) until you need it to restore your System.
    So how can I restore the system (Settings), when my HDD, SDD or USB-Stick is damaged, I don't have access to it (and my Backup) anymore and must make a fresh Install ?
    I find it stupid to make a "Backup" on the same Drive my System is on.
    When I use
    why is the Backup-File only going to the "Backup"-Folder, and why can 't I decide where I want to put my Backup (for example maybe an USB-Stick) so that I can keep it at a save place ?
  • When I use
    couldn't you ?! :angel:
  • I didn't give me some choice
    what happens if you tap/click/select and hit enter the two white points in the backup tool window ? [1]
    hint: two points in linux means the upper directory
    Questions:
    as you said you're running LE from an usb stick, where is the need to move the backup file (at this point) ?
    isn't the backup directory not already on the same usb stick too ?
    or better:
    the backup directory is one entry of the directory structure of a running LE and in this case: on the usb stick
    so, aren't you already done with creating the backup in it's default backup directory (which *is* already on the usb stick) and pulling the stick after you powered the box down ?
    [1]
    there seems to be a bug regarding the cancel-button in that window: a backup is in any case created
    at least here on (yesterdays) nightly
