You might need a reboot or "partprobe /dev/sdb" to have the kernel refresh the partition table before running e2fsck.
But Since I Am Here.. Need To Set Up 8TB Drive
Michale -
December 18, 2021 at 9:46 PM -
Thread is Resolved
How exactly would I adjust the offset for my particular setup.
Let parted decide: mkpart mylabel ext4 0% 100%
Please note that the first mkpart parameter for gpt is the gpt partition label.
Use unit s or unit B (check help unit) to see the exact alignment with print.
.. I am guessing the 512B/4096B has something to do with it
The hard disk is internally using 4096 byte sectors but the command interface counts 512 byte sectors.
Windows became my addiction
diskpart is not that different
OK It looks like I need to scan the HD as per Joe Average's initial suggestion.. It will likely take a while, so I will check back in when it's done..
Thanx to all for the help and suggestions... It's very much apprecaited.. -
I always thought it meant Keep It Simple, Stupid...
Klojum you're talking scrap !
Then the fsck.ext4 gave me this..
fsck.ext4 or e2fsck shouldn't run on an mounted partition
fsck.ext4(8): check ext2/ext3/ext4 file system - Linux man page
Chap. "Description",
2cd Paragraph:
cit.: "Note that in general it is not safe to run e2fsck on mounted filesystems. ..."
I am thinking that this means what Joe Average was talking about above?? That the HD has some bad areas??
Bad areas or Bad Blocks are damaged area's on a disk.
Superblock are ~sorta~ additional copies of partition table/filesystem info's
a partition table is created when you create a partition on the disk
Superblocks are created when you create the ext4 filesystem
e2fsck or fsck.ext4 checks Superblocks too
if e2fsck cries regarding Superblocks something is up with your filesystem
in general:
a disk should always be unmounted when you
- create a partition [1]
- create a filesystem
- fsck the filesystem (though, a readonly switch for mounted FS is available)
[1]
afterwards the linux kernel isn't aware of the new created partition
either a reboot or partprobe (thanks @frakkin64) should do the re-reading
you could always feed google with the commands you aren't clear about e.g.
man parted
after creation of the 8TB partition, did you create a file systen, e.g. with mkfs.ext4?
in your commands I see only fsck.ext4 (probably on an uninitialied partition).
