Beelink Mini MXIII WIFI and BT
  • This is actually a great sign...this means it should work!!! Reboot and look for wireless under network
    Edited once, last by mytbyte ().
    Under connections in LibreELEC settings right??
    Horray it worked. Thanks for your patience in helping me. It means a lot.
    MXQ M10 S805 - LibreELEC 8.1.9
    NEXBOX A5 S905X - LibreELEC 8.1.9
    BEELINK MXIII II S905X - LibreELEC 8.1.10
    Edited once, last by kodiuser1 ().
  • Under network you should have "wireless networks" selecion...disable it then enable it and you shoiuld have neraby wireless networks available under "connections"
    Oh, I missed that you made it work, I'm glad to help...now we wait to see if we get bluetooth support as well...this box only has 2 USB connectors, hate to loose one to the airmouse IR receiver...
  • I did have it working. I then did a reboot now no wireless networks are showing under connections or network. That sucks after all your work and help.
    Now I have it back up again.
    Any idea how to make it work every reboot without ash?
    Nope it won't pick up the wireless adapter on reboot.
  • It happens every time with me if I disconnect the Ethernet.
    If I have Ethernet plugged in then it will bring up the wireless networks and I just have to uncheck wireless and re connect.
  • Not with me...I disconnected the Ethernet, even dsabled it and wireless option is stil availble after reboots or power offs...I only need to deactivate/reactivate to get the availbale wifi networks...
  • Lucky for you. I've lost my wifi again and it didn't come back after a reboot.
    Do you think this will get fixed in another build or device tree?
  • I have been trying to make the kernel module for Aigaile chips load automatically but unfortunately I couldn't make it. The only thing I achieved is an easier hack:
    • first install this devel version - when updating from 7.0.2.009 you don't need a device tree: LibreELEC-S905.aarch64-7.0-devel-20161116235711-r23437-g73c3cef.img.gz
    • if you have the previous "hack" in autostart.sh, delete it - either the whole file or lines with the hack only
    • in Configuration folder (/storage/.config over SSH) enter modules-load.d directory and create file named wifi.conf and content cfg80211_qca. A SSH one-liner for this is echo cfg80211_qca > /storage/.config/modules-load.d/wifi.conf
    • reboot
    Please report if WiFi works "automatically" with this version and after following these steps.
  • Just to clarify @kazaq here is what I did:
    1) Updated to the latest devel LibreELEC-S905.aarch64-7.0-devel-20161116235711-r23437-g73c3cef.img.gz
    2) Created a file named wifi.conf with the following contents:
    1. [code]
    2. cfg80211_qca
    [/code]
    3) Put this wifi.conf file in the modules-load.d directory .
    4) Ran the following command via ssh putty:
    1. [code]
    2. echo cfg80211_qca > /storage/.config/modules-load.d/wifi.conf
    [/code]
    5) Rebooted.
    Once I did that I got the wireless networks tab coming up under network. The picture is a screenshot:
    However, even if I deactivate and reactivate the wireless networks, I still don't get any wireless connections. Like in the screenshot below:
    Hope this helps.
  • Please let me know what you need and tell me how to collect a log and I'll do it around this time tomorrow for you with pleasure.
  • Great I will try it. Thanks.
  • Hi @kasaq.
    Here is what I did. I deleted the autostart.sh and the wifi.conf files.
    Updated to the devel in post #50.
    Rebooted. Box updated and rebooted.
    Went to Network. The wifi box is there still, but there are no connections.
    Here is my Log. Dropbox - Link not found
  • Ahh figured it out.
    Here you go.
