Hello,
I have big problems with the PVR-Simple IPTV Client 3.9.8.1 and Libreelec 9.2.6. Since Sunday, not a single channel has worked. If I press play it looks normal for a second as if the channel starts, but then just stops. I tried older Clients too.
I have a M3U-playlist for my TV channels in which my access data is also stored in every URL (http://___.___.___/user/pass/channel___). Until Saturday it always worked fine, but since then it no longer works.
In the Kodi log, I have the following entries (401 for not authorised) when starting a channel:
2021-01-22 14:18:55.173 T:3011842656 NOTICE: VideoPlayer::OpenFile: pvr://channels/tv/Alle Kanäle/pvr.iptvsimple_1253303126.pvr
2021-01-22 14:18:55.175 T:2860016496 NOTICE: Creating InputStream
2021-01-22 14:18:55.271 T:2860016496 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 401
2021-01-22 14:18:55.271 T:2860016496 ERROR: CCurlFile::Open failed with code 401 for http://client.___.___:8080/___/___/___:
2021-01-22 14:18:55.400 T:2860016496 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 401
2021-01-22 14:18:55.400 T:2860016496 ERROR: CCurlFile::Open failed with code 401 for http://client.___.___:8080/___/___/___:
2021-01-22 14:18:55.400 T:2860016496 ERROR: Open - failed to open source <http://client.___.___:8080/___/___/___>
2021-01-22 14:18:55.400 T:2860016496 ERROR: CVideoPlayer::OpenInputStream - error opening [pvr://channels/tv/AllChannels/pvr.iptvsimple_1253303126.pvr]
2021-01-22 14:18:55.400 T:2860016496 NOTICE: CVideoPlayer::OnExit()
2021-01-22 14:18:55.462 T:3011842656 NOTICE: CVideoPlayer::CloseFile()
2021-01-22 14:18:55.463 T:3011842656 NOTICE: VideoPlayer: waiting for threads to exit
2021-01-22 14:18:55.463 T:3011842656 NOTICE: VideoPlayer: finished waiting
			Display More
	If I access the URL via wget or curl from the Raspberry everything is ok, only via the addon I get the 401.
And now the strange thing: On every other device with Kodi (Raspberry Pi 2 with Libreelec, Raspberry Pi 4 under Ubuntu, PC, smartphone, tablet) everything can be played normally. Even VLC or similar players. Each time I use the same playlist, which I provide locally in my home network via a web server.
Even a completely freshly set up Libreelec on another SD card does not work. And it's exactly the same with a friend.
According to "Last updated addons", there was no update.
What could be the reason for this? Any ideas?
Many thanks in advance!
Kind regards
Tresi
