Dear All,
I was wondering whether if it´s possible to let libreelec forward an incoming audio signal to the output, either mixed with audio playing libreelec (from for instance a movie) or without it.
I´d be using a hifiberry board for everything here, and I´d need to make sure that the system can give me the lowest latency possible from input to output as well, as part of the inputsound is from a midi keyboard. I assume that the latency would be ruined if I use audio through HDMI, so I´d be using a hifiberry with optical in and analog out.
And if this all works, will there be issues with audio and picture out of sync, when watching movies on libreelec, due to audio no longer going via HDMI?
