Switching Fire TV 4k Remote from fire tv stick to pi 4 to vice versa
  • so i recently installed libreelec on my kodi 4b 8 gb on an lg 4k tv which also has the fire tv 4k stick attached to it and when i want to use the 4k fire tv remote with the pi 4, i first have to fo in fire tv settings, unpair it from there, then connect and pair in kodi and then when i have to use it with fire tv, the reverse.
    Is there an easier way to use the same remotes with fire tv and pi 4 without going through all this rigmarole?
  • Bluetooth restricts “pairing” to one device at a time, so it is not possible for a Bluetooth remote to control more than one device simultaneously.
  • Technically it's possible. Idea: Pair your RC with the RPi, attach a Bluetooth adapter to the RPi and pair your Fire TV stick with that adapter. Someone successfully did an IR-to-IR project, which could be helpful for Bluetooth, too: click.
