  • I have uploaded 7.95.beta5 build with Kodi 17.0. I'm mobile-only now, will update OP in a few hours.
  • LibreELEC-S805.arm-8.0-7.95.beta5-MXQ.img.gz, beta4a, or beta4 have not worked on my mk808b plus. LibreELEC-S805.arm-8.0-7.90.beta3.img.gz continues to work fine.
  • Latest Beta5, AAC 48.0 kHz stereo audio is just noise. Red top MXQ. HDMI for audio.
    Edited once, last by rev6 ().
    Please temporarily set audio output configuration to fixed 44.1kHz or choose SPDIF as main audio output. I will try to fix it today evening.
  • Cheers, very helpful post.
    Just in case anyone else needs help, if you open a SSH session, type in the following command; installtointernal
    Paul
    That is in the first post. Welcome.
  • Finally got this working, first i put the image onto sd and booted from that, then i got the remote.conf file and saved it into the configs folder and rebooted from ssh and remote worked so i did installtointernal and all good. Working fine just noticed its abit slower compared to the 7 builds.
    Sent from my ONEPLUS A3003 using Tapatalk
  • Will give this a try in the week, hopefully speed improvements are better, i find it takes alot longer when clicking through movies
  • Kazaq,
    Thanks for all your hard work on these great builds.I am running MXQ 7.95beta6 build on a MXV box. Everything is working well except I can't play any HD video. When I try to play an HD video the screen goes black and I can hear audio but no video. Also the play and pause menu buttons are not visible.
    I have tried your other beta builds with the same results.
  • I have no issues playing HD videos. Unless you post logs and a sample as instructed I won't be able to help.
  • Playback seems fine here so far with Beta6. Text on the stock skin can look a bit blurry depending on the character, not sure if it's isolated to device/TV.
