master does not build for imx6
  • Hello,
    it seems that iMX6 does currently not build, since a patch for etnaviv does not apply properly. Not sure if this is the right place to report here....
    Thanks,
    Rainer
  • I've pinged the maintainer. The workaround will be to create another $PROJECT entry in packages/linux/package.mk so that NXP project is compiled using an eariler kernel that the patches were generated agaisnt. Until a proper kernel bump is done.
