Raspberry PI2 installing problem.
  • Hi guys, I'm trying to install the latest LibreELEC image on an SD card using USB-SD Creator. It creates SD without any error, but then the system stuck on rainbow square while booting.
    On the same SD card LibreELEC installation via NOOBS goes without any problems resulting in working system. The same USB creator perfectly makes a bootable system on the same SD card for S905X box
    What I'm doing wrong in first case?
    Thank you, Dmitry
