ver 20220622 rk33xx rk356x - kernel 5.18.5
Unofficial LE for RK356x RK3328\RK3399 RK3588(s)
balbes150 -
November 25, 2019 at 12:41 PM -
Thread is Resolved
ver 20220705 rk33xx and rk356x - kernel 5.18.9
ver 20220719 rk33xx and rk356x - kernel 5.18.12
balbes150 - found some time to test your image on the Odroid-M1 (booting with the SPI factory Apr 24 2022 u-boot - and "fw_setenv skip_spiboot true" and "fw_setenv panel display_vu8m") I have tested both the Petitboot and Odroid ubuntu image on both the HDMI/DSI.
Log from the boot.Code
Display MoreDDR Version V1.09 20210630 In ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB tdqss: cs0 dqs0: 48ps, dqs1: -96ps, dqs2: -48ps, dqs3: -120ps, tdqss: cs1 dqs0: 48ps, dqs1: -96ps, dqs2: -48ps, dqs3: -120ps, change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x61 change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 1560MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x1c cs 0: the read t raining result: DQS0:0x2e, DQS1:0x34, DQS2:0x35, DQS3:0x2e, min : 0xc 0xc 0x10 0xc 0x1 0x4 0x8 0x3 , 0xb 0xa 0x2 0x3 0x10 0xa 0xe 0xa , 0x12 0x13 0xc 0xa 0x5 0x2 0x5 0x5 , 0xc 0x7 0x7 0x2 0xe 0xf 0xa 0xd , mid :0x26 0x27 0x2a 0x27 0x19 0x1d 0x20 0x1c ,0x26 0x25 0x1c 0x1f 0x2a 0x27 0x27 0x24 , 0x2d 0x2f 0x27 0x26 0x21 0x1e 0x20 0x21 ,0x26 0x22 0x21 0x1d 0x29 0x2a 0x25 0x28 , max :0x40 0x42 0x44 0x43 0x32 0x36 0x39 0x36 ,0x42 0x40 0x37 0x3c 0x44 0x44 0x40 0x3e , 0x49 0x4c 0x42 0x43 0x3d 0x3b 0x3b 0x3e ,0x40 0x3d 0x3c 0x39 0x44 0x45 0x41 0x44 , range:0x34 0x36 0x34 0x37 0x31 0x32 0x31 0x33 ,0x37 0x36 0x35 0x39 0x34 0x3a 0x32 0x34 , 0x37 0x39 0x36 0x39 0x38 0x39 0x36 0x39 ,0x34 0x36 0x35 0x37 0x36 0x36 0x37 0x37 , the write t raining result: DQS0:0x25, DQS1:0x9, DQS2:0x13, DQS3:0x5, min :0x6e 0x71 0x73 0x70 0x62 0x66 0x6b 0x6a 0x68 ,0x46 0x45 0x3e 0x44 0x4a 0x48 0x4a 0x47 0x42 , 0x5d 0x5e 0x57 0x56 0x4f 0x4c 0x50 0x55 0x53 ,0x4a 0x47 0x45 0x43 0x4c 0x4d 0x4c 0x51 0x45 , mid :0x8a 0x8d 0x8f 0x8c 0x7a 0x7e 0x83 0x81 0x7e ,0x61 0x61 0x58 0x5c 0x64 0x63 0x64 0x62 0x5e , 0x7a 0x79 0x71 0x71 0x68 0x66 0x69 0x6f 0x6e ,0x64 0x61 0x5f 0x5d 0x67 0x68 0x64 0x69 0x5f , max :0xa7 0xa9 0xab 0xa8 0x93 0x96 0x9c 0x98 0x94 ,0x7d 0x7d 0x72 0x75 0x7f 0x7e 0x7e 0x7d 0x7a , 0x97 0x94 0x8b 0x8d 0x82 0x80 0x83 0x89 0x89 ,0x7e 0x7c 0x79 0x77 0x82 0x84 0x7c 0x82 0x7a , range:0x39 0x38 0x38 0x38 0x31 0x30 0x31 0x2e 0x2c ,0x37 0x38 0x34 0x31 0x35 0x36 0x34 0x36 0x38 , 0x3a 0x36 0x34 0x37 0x33 0x34 0x33 0x34 0x36 ,0x34 0x35 0x34 0x34 0x36 0x37 0x30 0x31 0x35 , cs 1: the read t raining result: DQS0:0x2d, DQS1:0x31, DQS2:0x36, DQS3:0x2e, min : 0xc 0xd 0x10 0xd 0x1 0x4 0x7 0x3 , 0xa 0x7 0x2 0x1 0x10 0xa 0xc 0x9 , 0x11 0x11 0xc 0xa 0x7 0x1 0x3 0x7 , 0xb 0x7 0x8 0x1 0xf 0xf 0xc 0xe , mid :0x25 0x27 0x29 0x27 0x19 0x1c 0x1f 0x1b ,0x24 0x22 0x1b 0x1c 0x29 0x25 0x25 0x23 , 0x2c 0x2d 0x27 0x26 0x21 0x1e 0x1f 0x22 ,0x26 0x22 0x23 0x1d 0x29 0x2a 0x26 0x29 , max :0x3e 0x42 0x42 0x42 0x32 0x35 0x37 0x34 ,0x3f 0x3d 0x35 0x38 0x42 0x40 0x3e 0x3d , 0x47 0x4a 0x42 0x42 0x3c 0x3b 0x3b 0x3d ,0x41 0x3d 0x3e 0x39 0x43 0x46 0x41 0x45 , range:0x32 0x35 0x32 0x35 0x31 0x31 0x30 0x31 ,0x35 0x36 0x33 0x37 0x32 0x36 0x32 0x34 , 0x36 0x39 0x36 0x38 0x35 0x3a 0x38 0x36 ,0x36 0x36 0x36 0x38 0x34 0x37 0x35 0x37 , the write t raining result: DQS0:0x25, DQS1:0x9, DQS2:0x13, DQS3:0x5, min :0x70 0x72 0x73 0x72 0x60 0x67 0x6b 0x6a 0x68 ,0x4a 0x49 0x42 0x45 0x4d 0x4c 0x4d 0x4b 0x45 , 0x5c 0x5e 0x58 0x55 0x50 0x4c 0x50 0x55 0x54 ,0x4e 0x4a 0x47 0x45 0x50 0x50 0x4e 0x53 0x47 , mid :0x8c 0x8d 0x8f 0x8d 0x7a 0x7e 0x84 0x82 0x7e ,0x66 0x65 0x5c 0x5e 0x67 0x66 0x65 0x65 0x61 , 0x79 0x79 0x73 0x71 0x69 0x67 0x6a 0x6e 0x6e ,0x68 0x65 0x61 0x60 0x69 0x6c 0x68 0x6d 0x61 , max :0xa8 0xa9 0xab 0xa8 0x94 0x96 0x9d 0x9b 0x95 ,0x82 0x82 0x76 0x78 0x82 0x81 0x7e 0x80 0x7d , 0x97 0x94 0x8e 0x8d 0x83 0x82 0x85 0x88 0x89 ,0x82 0x80 0x7c 0x7b 0x83 0x88 0x82 0x88 0x7c , range:0x38 0x37 0x38 0x36 0x34 0x2f 0x32 0x31 0x2d ,0x38 0x39 0x34 0x33 0x35 0x35 0x31 0x35 0x38 , 0x3b 0x36 0x36 0x38 0x33 0x36 0x35 0x33 0x35 ,0x34 0x36 0x35 0x36 0x33 0x38 0x34 0x35 0x35 , CA T raining result: cs:0 min :0x56 0x57 0x4a 0x4a 0x4b 0x45 0x50 ,0x50 0x50 0x44 0x44 0x43 0x44 0x4e , cs:0 mid :0x95 0x94 0x88 0x87 0x88 0x81 0x81 ,0x8f 0x8c 0x83 0x81 0x83 0x81 0x7f , cs:0 max :0xd4 0xd2 0xc6 0xc4 0xc6 0xbe 0xb3 ,0xce 0xc9 0xc3 0xbe 0xc4 0xbf 0xb0 , cs:0 range:0x7e 0x7b 0x7c 0x7a 0x7b 0x79 0x63 ,0x7e 0x79 0x7f 0x7a 0x81 0x7b 0x62 , cs:1 min :0x50 0x5a 0x45 0x4d 0x47 0x49 0x53 ,0x4f 0x53 0x43 0x47 0x42 0x49 0x4e , cs:1 mid :0x93 0x92 0x88 0x87 0x88 0x81 0x84 ,0x91 0x8d 0x86 0x81 0x85 0x83 0x80 , cs:1 max :0xd6 0xcb 0xcc 0xc1 0xc9 0xb9 0xb6 ,0xd4 0xc8 0xc9 0xbb 0xc9 0xbd 0xb3 , cs:1 range:0x86 0x71 0x87 0x74 0x82 0x70 0x63 ,0x85 0x75 0x86 0x74 0x87 0x74 0x65 , out U-Boot SPL board init U-Boot SPL 2017.09 (Apr 24 2022 - 07:36:50) Trying to boot from MMC1 MMC error: The cmd index is 0, ret is -110 mmc_init: -110, time 4 spl: mmc init failed with error: -110 Trying to boot from MMC2 spl: partition error Trying to boot from MTD2 No misc partition ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(2f01bd8955...) + OK ## Checking uboot 0x00a00000 ... sha256(59105c2b16...) + OK ## Checking fdt 0x00b1bca0 ... sha256(06b6d16a4d...) + OK ## Checking atf-2 0xfdcc9000 ... sha256(f1fecab971...) + OK ## Checking atf-3 0xfdcd0000 ... sha256(d7aa45eb18...) + OK ## Checking optee 0x08400000 ... sha256(b8cddafab0...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 416.438 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-152-g4e725b15f:cl NOTICE: BL31: Built : 10:51:13, Jul 15 2021 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: pmu v1 is valid INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 I/TC: I/TC: Start rockchip platform init I/TC: Rockchip release version: 1.0 I/TC: OP-TEE version: 3.6.0-307-g0b06ae94 #1 Fri May 7 01:52:27 UTC 2021 aarch64 I/TC: Initialized INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot 2017.09 (Apr 24 2022 - 07:36:50 +0000) Model: Hardkernel ODROID-M1 PreSerial: 2, raw, 0xfe660000 DRAM: 7.7 GiB Sysmem: init Relocation Offset: ecc5e000 Relocation fdt: eb3f8990 - eb3fecf0 CR: M/C/I SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 16 MiB Bootdev(atags): mtd 2 PartType: EFI MMC error: The cmd index is 0, ret is -110 mmc_init: -110, time 33 ** Bad device mmc 2 ** MMC error: The cmd index is 0, ret is -110 mmc_init: -110, time 33 ** Bad device mmc 2 ** MMC error: The cmd index is 0, ret is -110 mmc_init: -110, time 33 ** Bad device mmc 2 ** SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 16 MiB device 0 offset 0x400000, size 0xc00000 SF: 12582912 bytes @ 0x400000 Read: OK device 0 offset 0xe0000, size 0x20000 SF: 131072 bytes @ 0xe0000 Read: OK No misc partition boot mode: None FIT: No boot partition ### CRAMFS load complete: 127256 bytes loaded to 0xa100000 ### CRAMFS load complete: 6428 bytes loaded to 0x2000000 Error binding driver 'gpio_led': -22 Some drivers failed to bind I2c3 speed: 100000Hz PMIC: RK8090 (on=0x40, off=0x00) vdd_logic init 900000 uV vdd_gpu init 900000 uV vdd_npu init 900000 uV io-domain: OK SF: Detected mx25u12835f with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0 Could not find baseparameter partition Rockchip UBOOT DRM driver version: v1.0.1 VOP have 2 active VP vp0 have layer nr:3[1 3 5 ], primary plane: 5 vp1 have layer nr:3[0 2 4 ], primary plane: 4 vp2 have layer nr:0[], primary plane: 0 Using display timing dts dsi@fe060000: detailed mode clock 132000 kHz, flags[8000000a] H: 1080 1095 1097 1127 V: 1920 1935 1937 1952 bus_format: 100e VOP update mode to: 1080x1920p0, type: MIPI0 for VP1 VOP VP1 enable Smart0[1920x1080->1080x1920@0x0] fmt[0] addr[0xed800000] final DSI-Link bandwidth: 876 Mbps x 4 xfer: num: 2, addr: 0x50 xfer: num: 2, addr: 0x50 Monitor has basic audio support Could not find baseparameter partition mode:3840x2160 hdmi@fe0a0000: detailed mode clock 594000 kHz, flags[5] H: 3840 4016 4104 4400 V: 2160 2168 2178 2250 bus_format: 2025 VOP update mode to: 3840x2160p0, type: HDMI0 for VP0 VOP VP0 enable Smart1[1920x1080->3840x2160@0x0] fmt[0] addr[0xed800000] CEA mode used vic=97 final pixclk = 594000000 tmdsclk = 594000000 xfer: num: 2, addr: 0x54 xfer: num: 1, addr: 0x54 [dw_hdmi_i2c_write] write offset 03 success xfer: num: 2, addr: 0x54 xfer: num: 1, addr: 0x54 [dw_hdmi_i2c_write] write offset 21 success PHY powered down in 0 iterations xfer: num: 2, addr: 0x54 xfer: num: 1, addr: 0x54 [dw_hdmi_i2c_write] write offset 21 success PHY PLL locked 1 iterations PHY powered down in 0 iterations xfer: num: 2, addr: 0x54 xfer: num: 1, addr: 0x54 [dw_hdmi_i2c_write] write offset 21 success PHY PLL locked 1 iterations sink has audio support hdmi_set_clk_regenerator: fs=48000Hz ftdms=594.000MHz N=10240 cts=990000 Model: Hardkernel ODROID-M1 41831 bytes read in 33 ms (1.2 MiB/s) VOP VP1 enable Smart0[1280x720->1080x1920@0x0] fmt[1] addr[0xedfe907a] VOP VP0 enable Smart1[1280x720->3840x2160@0x0] fmt[1] addr[0xedfe907a] CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 780000 KHz gpll 1188000 KHz cpll 1000000 KHz npll 1200000 KHz vpll 660000 KHz hpll 594000 KHz ppll 200000 KHz armclk 816000 KHz aclk_bus 150000 KHz pclk_bus 100000 KHz aclk_top_high 500000 KHz aclk_top_low 400000 KHz hclk_top 150000 KHz pclk_top 100000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz No misc partition Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 232 bytes read in 4 ms (56.6 KiB/s) 1: LibreELEC Retrieving file: /KERNEL reading /KERNEL 86606336 bytes read in 7174 ms (11.5 MiB/s) append: boot=LABEL=LIBREELEC disk=LABEL=STORAGE quiet console=ttyS2,1500000 console=tty0 systemd.debug_shell=ttyS2 coherent_pool=2M cec.debounce_ms=5000 Retrieving file: /dtb/rockchip/rk3568-firefly-roc-pc.dtb reading /dtb/rockchip/rk3568-firefly-roc-pc.dtb 120396 bytes read in 15 ms (7.7 MiB/s) Fdt Ramdisk skip relocation No misc partition ## Flattened Device Tree blob at 0x0a100000 Booting using the fdt blob at 0x0a100000 Using Device Tree in place at 000000000a100000, end 000000000a12064b can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x09400000 - 0xf0000000 (size: 0xe6c00000) Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000) Total: 10377.376 ms Starting kernel ... [ 0.000000] ITS ALLOCATE PROP WORKAROUND [ 1.972334] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active. [ 1.985752] rockchip-pinctrl pinctrl: pin gpio1-4 already requested by vcc-hub-reset-regulator; cannot claim for fe680000.serial [ 1.986795] rockchip-pinctrl pinctrl: pin-36 (fe680000.serial) status -22 [ 1.987408] rockchip-pinctrl pinctrl: could not request pin 36 (gpio1-4) from group uart4m0-xfer on device rockchip-pinctrl [ 1.988505] dw-apb-uart fe680000.serial: Error applying setting, reverse things back [ 2.041518] rk_gmac-dwmac fe010000.ethernet: no regulator found [ 2.216654] rk_gmac-dwmac fe2a0000.ethernet: no regulator found [ 2.814343] arm-scmi firmware:scmi: Failed. SCMI protocol 19 not active. [ 2.825643] arm-scmi firmware:scmi: Failed. SCMI protocol 21 not active.
Using your .... 20220726 .... -rk3568.img.gz image
LibreELEC:/ # dmesg - http://ix.io/46dL
pastekodi - http://ix.io/46dJ
- no display on either the MIPI-DSI or the HDMI for an hour or so
- Well after going out for an hour or so. My LG 4K 27" Screen happily had LE11 on it when I came home waiting for me to set it up.
Display More[ 5610.003703] audit: type=1334 audit(1659270624.288:16): prog-id=17 op=LOAD [ 5610.039456] audit: type=1334 audit(1659270624.328:17): prog-id=0 op=UNLOAD [ 5675.340246] audit: type=1334 audit(1659270689.631:18): prog-id=18 op=LOAD [ 5675.366149] audit: type=1334 audit(1659270689.661:19): prog-id=0 op=UNLOAD [ 5682.222769] audit: type=1334 audit(1659270696.512:20): prog-id=19 op=LOAD [ 5682.285887] audit: type=1334 audit(1659270696.582:21): prog-id=0 op=UNLOAD [ 5692.445049] Bluetooth: Core ver 2.22 [ 5692.445067] Bluetooth: Starting self testing [ 5692.455976] Bluetooth: ECDH test passed in 10649 usecs [ 5692.459644] Bluetooth: SMP test passed in 3507 usecs [ 5692.459660] Bluetooth: Finished self testing [ 5692.459750] NET: Registered PF_BLUETOOTH protocol family [ 5692.459755] Bluetooth: HCI device and connection manager initialized [ 5692.459770] Bluetooth: HCI socket layer initialized [ 5692.459777] Bluetooth: L2CAP socket layer initialized [ 5692.459794] Bluetooth: SCO socket layer initialized [ 5692.495444] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 5692.495462] Bluetooth: BNEP filters: protocol multicast [ 5692.495477] Bluetooth: BNEP socket layer initialized [ 5692.505318] audit: type=1334 audit(1659270706.802:22): prog-id=20 op=LOAD [ 5692.506101] audit: type=1334 audit(1659270706.802:23): prog-id=21 op=LOAD [ 5692.506471] audit: type=1334 audit(1659270706.802:24): prog-id=22 op=LOAD [ 5722.822793] audit: type=1334 audit(1659270737.124:25): prog-id=0 op=UNLOAD [ 5722.822820] audit: type=1334 audit(1659270737.124:26): prog-id=0 op=UNLOAD [ 5722.822834] audit: type=1334 audit(1659270737.124:27): prog-id=0 op=UNLOAD [ 5747.535475] Bluetooth: RFCOMM TTY layer initialized [ 5747.535508] Bluetooth: RFCOMM socket layer initialized [ 5747.535535] Bluetooth: RFCOMM ver 1.11
- played a movie
- it crashed ...
Code[ 7034.065319] failed toip-drm display-subsystem: swioes), total 32768 (slots), used 316 (sld to map scatterlist [ 7034.165tem: swiotlb buffer is full (sz: 6ts), used 316 (slots) [ 7034.198707] failed to map schip-drm display-subsystem: swiotlb tes), total 32768 (slots), 3ed to map scatterlis [ 7088.449527] [3416]: Failed to unmount /flash: Device or resource busy [ 7088.456629] watchdog: watchdog0: watchdog did not stop! [ 7088.459407] systemd-shutdown[1]: Failed to finalize file systems, loop devices, ignoring. [ 7088.571533] gpiod_set_value: invalid GPIO (errorpointer) [ 7088.577114] reboot: Restarting system
- but a good start.
** Again no video on start ** it came along after a while (an hour)
Video did come along, I needed to run systemctl restart kodi. As it was stuck on the LibreELEC boot image with the boot text in the top left corner.
ver 20220819 kernel 5.19.1
This is the wrong DTB for your M1 model, it is only for Station P2. You need to change the setting to the correct DTB
Thanks for the test builds. I installed this Quartz64a build and it easily passes my test of hosting a pvr server and allowing Kodi to play live TV on the host and stream to another box, while recording a third show, with lots to spare (writing to SD)
However some that things continue to be a problem
- emmc installs complain that LIBRELEC is not mounted. SD card installs work fine.
- there is no OSD over video.
- no MAC address
Martin
I have not checked the installation mode on eMMC. How do you perform the installation on eMMC ? Can you show the UART startup log from eMMC ?
For the menu to work properly, you must change the player settings. Open settings, switch to expert mode, open player settings, video, change rendering mode from DRM to EGL.
no MAC address
sorry, I don't understand what it's about, write in more detail.
Here is the boot sequence
I just burn to emmc with Etcher since installtoemmc.sh doesn't work.External Content pastebin.comContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy.Turning on EGL rendering gave me the OSD thanks.
When I say no MAC address, I need to use a fixed IP since every time LE boots it has an new MAC and my DHCP server gives a new IP address.
Judging by the log, the system is running eMMC. What is the problem ? Show the startup log with the remote option in extlinux.conf "quiet".
To fix the address, you can use several options.
Set a static IP address in the LE settings. Either add the variable "mac=" to extlinux.conf or register fixed settings via LE settings.
I get this on the screen and it stops
Version 20220824. fixed installation on eMMC for rk356x models. Important. the order of installation on eMMC for rk356x. Before installing LE, you must install ArmbianTV, this is necessary to update u-boot in eMMC (without updating u-boot, there are no guarantees that the system will start from eMMC). After installing Armbian, we run and install LE. To install LE, open the LE settings -> eMMC menu and select the eMMC installation mode in it. The automatic procedure for installing LE on eMMC will be started, after the installation is completed, the system automatically shuts down, disconnect the media and start the system. Please note, after updating u-boot in eMMC, you can run any Armbian\LE\AltLinux system from any media (SD card or USB media).
see the details in this topic
I am not sure what you mean by ArmbianTV but I installed one of the Armbian desktops I had made sure it worked ok, then run the LE setup to emmc and I guess it finishes since it goes to black screen. It did something because desktop no longer starts but neither does LE, the boot hangs with the pxeboot.
It has U-Boot SPL 2022.04-armbian (Jul 07 2022 - 08:50:57 +0300) and log is here
External Content pastebin.comContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy.Martin
See ArmbianTV images for details in this topic.
Armbian and LibreELEC and AltLinux for Quartz64
Judging by the log, u-boot does not see extlinux.conf on eMMC. Write ArmbianTV to a USB flash drive, connect to Quartz64a (only eMMC and USB flash drive should be connected, SD card should be disconnected). Run ArmbianTV from a USB flash drive and check the contents of the eMMC, there should be two partitions and on the first file /extlinux/extlinux.conf. Try writing LE to a USB flash drive and repeat the installation procedure. My installation on eMMC runs without problems on all devices (Qurtz64a , Station P2\M2, Banana PI R2 pro).
I see the release notes some say Armbian and some say ArmbianTV but I couldn't find an image with ArmbianTV.
Martin
Yes those are what I have been using use but they just say Armbian not ArmbianTV on the filenames. Maybe you use the term interchangeably?
