is it possible to add support Orange Pi5 (RK3588S) ?
any questions, please contact the equipment manufacturer (orangepi).
Ver 20231031-rk3588.
Added support for USB 2.0.
Added support for the fan on Khadas EDGE2.
Added Libreelec image for the ITX-3588j model (Full-fledged mini-PC).
ITX-3588J 8K AI Mini-ITX Mainboard - Delivery within 15 days_Embedded Board_ALL_Firefly Store
Ver 20231102 kernel 6.6
Ver 20231109 kernel 6.6.1
Ver 20231109-rk3588
Hi ,
i have a RK3399 X99 Box and LE on SDCard installed , is it possible to install to internal with Terminal and
what are the commands to do , thanks
greetings / gefattern
Hello RetroFan90
Bluetooth can't get it to work yet, I don't know if it depends on a new dtb file or the kernel. Or just need to add the driver, but I could never get it to work.
Anyway, my tvbox 99% works, everything works perfectly except the Bluetooth and being able to install Libreelec in the internal memory.
I hope the developers can help us here.
Hello, how are you? It also worked for me, but I was wondering if you have an updated version since I can't run the current ones.
Hi all,
I have some RockPi 4B Plus with soldered EMMC and a H96Max+. I have tried both with the official LE images.
RockPi 4B Plus runs but has 2 issues (no CEC, rejects wifi passphrase)
H96Max+ has one issue - no wifi.
Can these unofficial images fix these issues? If so, are there instructions on how to install? (25 pages has given me some idea, but not everything.)
Thanks!
"No WiFi" requires an explanation of what chip is inside the box before anyone can comment.
Ver 20231225 kernel 6.6.8
Ver 20231226-rk3588.
Ver 20240130 kernel 6.6.14
Ver 20240131-rk3588
Ver 20240221 for rk33xx and 35xx
Now all the images for rk33xx and rk35xx are in the same directory
Unoffical LE works with this ROCK 5 Model B( RK3588 )? if so, are there still errors that need to be fixed?
Does "RK35xx" mean the RK3528 is supported?
I'm hoping the same! but I believe it is not. There are no open source for rk3528, as I understand. Please anybody correct me if I'm wrong!
Oleg's images are largely based on the upstream kernel which supports RK3588 + RK3568. It's the first time I hear of RK3528 and while I don't actively track RK matters that's normally a good sign there's no support for that chipset.
