Hi,
I just installed the latest version of libreelec on my Intel NUC7CJYH, I turned on the ir receiver in bios and my HP MCE RC6 remote works great, all buttons doing as they should and on/off working perfectly too, the only issue I have is that after I get about 6-8 feet away from the box it doesn't pick up the signal. Unfortunately my sofa is about 10 feet away from the box, I installed new batteries in the remote but I have to keep standing up to get closer to the machine for the remote to work. Is there anything that I can do to fix this issue and make the remote work from further away? Or could it be the remote itself that is faulty? Thanks in advance,
MagicStars
