RPi4 1GB + LibreElec 9.1.002 + Hyperion Lights = no lights
  • Hello,
    i have a problem to get my hyperion lights up and running:
    Hardware setup is:
    RPi4 1GB - Armor case with 40x40x20 cooler
    WS2812B (5V white PCB)
    Power supply 5V 30A
    I'm able to connect with the HyperCon configuration program:
    After sending the configuration i get the message:
    Is this problem LibreElec alpha related on RPi4 or is there a problem with the hyperion sources?
    Thanks in advance for help ;)
    Mario
    PS: Okay it seems this is a problem which is hyperion related.
    Here you can find a binary which at least initializes
  • vpeter
    Approved the thread.
  • We got a couple of threads about Hyperion, use the search function. Read here for a RPi 3 success story.
    Flexin' vinyl, jammin' break beats. 8)
  • just install the Hyperion addon from the LibreELEC repository - no need to mess around with other hyperion binaries, they are usually built for Raspbian and known to cause issues.
    Read more about Hyperion on LE in the wiki Hyperion [LibreELEC.wiki]
  • Thanks for the replies, but Da Flex that didn't work here with my RPi4, so i went the hyperion forum during my research with the binary which works like a charm.
    HiassofT currently it's working perfectly, but thanks for the hint with the Hyperion addon from the LibreElec repository.
    I'm very curious, so i will test your way too today ;)
    Mario
    PS: Ok i tried to figure it out here without success. I removed everything vom Hyperion (addon and Hyperion ssh install).
    Installation from LibreElec repository was okay and i exchanged the configuration at the path:
    1. /storage/.kodi/userdata/addon_data/service.hyperion
    with my configuration file 'hyperion.config.json'-
    The result was/is: No function - no effect while startup - Hyperion remote on Android is unable to connect to the server. I think the service is not successfully started here. Maybe this is related to i'm using WS2812b (PWM at GPIO18 - Pin12) instead of WS2801.
  • What's the output if you do this from SSH?
    1. /storage/.kodi/addons/service.hyperion/bin/hyperiond.start
