I've found some info here : Raspberry Pi 3 built-in WiFi SSH NTP Problem · Issue #1519 · raspberrypi/linux · GitHub that seems to hit the spot.
After switching to LAN everything seems to work perfectly
Please provide details of what the problem is first and then:
Maybe it is the same issue as here: Upgrade LE 8.2.5 to 9.0.0: Wifi connected but no NTP link => SSL Certificate error !
Problem is very clear with a solutions.
