Finally figured out how to manually map an SMB path. (Need to fix it on reboot, but anyhow...)
Scanning 69 TV shows, maybe 2900 episodes.
Kodi for Windows and LibreElec, can scan these in, maybe 30 to 60 minutes at most?
Plex for Windows, around the same time.
Plex (Docker) 'under' LibreElec took nearly 24 hours, not completed,....
Many shows were identified (Show thumbnail, Show name, Season count, episode count) but actual EPISODE definitions, not pulled in, like episode title name, 'actual' episode thumbnail.
Where are these thumbnails saving, is there a space limit? Is it a disk IO issue?
Has anyone else seen this?
I'm running LibreElec from USB key (god, this is very well designed, I'm very impressed)
I just need to nail a few small issues and I can switch to this indefinitely.
Long story short:
Has anyone else had 'anomalies' scanning into the Plex server (docker) in the background, under LibreElec?
Does anyone else run from USB key reliably, with a huge library for Plex? (because generally, performance on USB key has been astoundingly surprisingly good for Kodi)
