I would like to explain a problem that has been blocking my installation for many months.
I would like to install a RPi 3 in an old CRT TV, to create a Smart CRT TV and watch old stuff on it
In order to have the best possible image quality, I use the famous RGB-Pi cable to output a RGB signal from the Pi (using a scart connector). (see http://www.rgb-pi.com)
There is a deditated distribution for this cable. On others, it is mandatory to set this configuration information in the config.txt to redirect A/V signals to GPIO.
For the video part, the cable designer has created a specific dtbo file.
On the audio side: the following information must also be added: dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
So I followed the instructions to adapt the librelec distribution by modifying the config.txt file
The video signal works well but no sound comes out... at all !![]()
I have try to change all the settings, try to add audio addons... nothing works.
Since the official distribution rgb-pi works perfectly (dedicated to retrogaming), I wonder if there would be no conflict regarding GPIO ports used for the sound?
Good to know : Very very rarely during my tests, the sound worked. But a simple reboot and all is lost. (not reproducible sadly)
Thanks in advance for your help.
BR
Dan
