I have attached the decompiled DTD extracted from boot.img inside my Android stock ROM that works. Had to rename extension to txt to allow attachment.
[S812] OTT M8S 2G RAM 8G ROM BCM4335 WIFI
begicj -
August 27, 2016 at 10:51 AM -
I have attached the decompiled DTD extracted from boot.img inside my Android stock ROM that works. Had to rename extension to txt to allow attachment.Yours .dtd file have small difference if compared with one that I used to compile. I will try compile with .dtd file that You post and upload working version to server.
My box is version M8 V9 if i remember, I will check this.
You can download firmware and uboot on this LINK
Please try with this uboot file. -
Meanwhile You can try THIS version, it is first working LE on my box. Just to test if there is problem because of 4k resolution suppport configuration in .dtd file.
Meanwhile You can try THIS version, it is first working LE on my box. Just to test if there is problem because of 4k resolution suppport configuration in .dtd file.Hi,
Tried downloading an OneDrive reports and no longer available. Flashed your version of u-boot, still no joy. u-boot is fine and boots LibreELEC os but still can't start Koid.
Thanks for you time one this.
Haven't flashed your Android image yet, I'll do that next.
[hr]Hi,
Your Android stock image flashes just fine too with WiFi working as expected. So it does appear to be something to do with the LibreELEC image. Perhaps the 4k patches. I'm currently connected to a 720p monitor right now.
Hi,
[hr]Your Android stock image flashes just fine too with WiFi working as expected. So it does appear to be something to do with the LibreELEC image. Perhaps the 4k patches. I'm currently connected to a 720p monitor right now.
Try THIS it is without 4k patch,
I tried 720p resolution on my tv and it works. Do you use HDMI-HDMI or HDMI-DVI cable?
Can you try your box on tv? -
Can you try your box on tv?Sure I can try on my main TV. I'll give the non 4k patch a try too. Thanks
I have compiled LE with yours .dtd file, you can try with THIS version.
Files are uploaded -
Files are uploadedThanks for your help on this, but still no joy. Piece of crap Chinese clone. Kodi doesn't seem to start but can't confirm if it's exactly the same problem as the console over COM is not enabled.
I'll have to get a build environment setup for your code base and add further tools into the image to try and debug EGL under framebuffer.
Thanks again
Thanks again
You can compile le from Kerber: LibreELEC.tv/ at libreelec-7.0-S8xx · surkovalex/LibreELEC.tv · GitHub
Device M8S options edit:
Kernel extra targets to build
KERNEL_UBOOT_EXTRA_TARGET="your file.dtd your file.dtb"And insert yours .dtd file in Linux source
m8 v8.9 doesnt work unless i make a sd card with the u-boot of the M8S.BCM4335.Oct29.2015 android firmware. Is there a way to add the u-boot to the librelec so i could use it without a sd card or already made firmware
thx in advance -
thx in advanceWhat do you mean "doesnt work unleas..."
Did you try install my build?Download zip file from link.
Unpack downloaded file to a FAT32-formatted SD card - there will be files as a result: factory_update_param.aml and a zip file with an update.
Install ROM using "toothpick" method. -
CCob's is noticeably different from our version (It seems you and I both have M8 V9_1), notably that the wifi chip and antenna are soldered to the exposed side of the PCB, whereas ours has only the solder traces for the chip and the antenna soldered to the opposite side.
the link above ain't workingyour build is in the updated first post too?
cause that the one i'm using
the only way my box boots if i have a sd card inserted that i made using bootmaker with android u-boot bin. -
CCob's is noticeably different from our version (It seems you and I both have M8 V9_1), notably that the wifi chip and antenna are soldered to the exposed side of the PCB, whereas ours has only the solder traces for the chip and the antenna soldered to the opposite side.Yea, mine seems to be an older revision. Although surprised that the stock firmware for your board works just fine on mine, especially the Android graphics which I believe works over EGL using SurfaceFlinger though. So I suspect the breakdown is somewhere between EGL<->directfb since this is where the graphics stack on Linux differs to Android.
the only way my box boots if i have a sd card inserted that i made using bootmaker with android u-boot bin.Yes it is in first post. Prepare sd card with original uboot file. Extract zip file to a sd card, copy aml_autoscript and recovery from your original fiware to sd card and give it try. If there is still problem with boot try reinstall android and use update app from android.
[hr]Yea, mine seems to be an older revision. Although surprised that the stock firmware for your board works just fine on mine, especially the Android graphics which I believe works over EGL using SurfaceFlinger though. So I suspect the breakdown is somewhere between EGL<->directfb since this is where the graphics stack on Linux differs to Android.
I will try enable serial console so you can trace where is problem with kodi
Display More
LIBREELEC 7.0.2 based on drieschel LE git for OTT M8S with BCM4335Update 29.11.2016: LE 7.0.2 M8S BCM 4335
Compiled with 4k resolution and working hyperion.
Remote is ok
CEC works
Lan works
Only 1G RAM (kernel panic if compiled with 2G)
Power off works(thanks to kszaq s power off patch) sometimes cant wake up with remote or with HDMI cec (only replug power adapter helps)
WIFI works (thanks to kszaq s Wi-Fi driver and kernel patch)
Bluetooth not works
Sudpend not worksi have try LibreELEC-S812.M8S.arm-8.0.0.zip from one drive only no internet add all
Hi,
It is first version it is not yet for use. what version of PCB board do you have? I can only test LE on M8 V9.1.
