OK, so I've restored my stock ROM from cyx_m8s_v8.6_bcm4335_8g2g_kodi_addons_160125_SD.zip, are you saying I should use a recovery app from Android or that once I have restored stock ROM then I should boot into recovery and apply the LibreELEC update?
I'm not sure if this will be useful to your situation but I installed LE using TWRP recovery.
You have to rename the above linked file to recovery.img and copy it to an SD card and then boot into the TWRP recovery using the toothpick method.
On a separate USB flash drive I unzipped Begicj's linked LE zip, which should put 2 files on said drive:
- LibreELEC-Amlogic.arm-M8S-7.0.2-update.zip
- factory_update_param.aml
Once you're in TWRP recovery, install the above .zip that you copied to your usb flash drive.
