Its a fresh install. I format SD with SDFormatter, then use Libreelec USB-SD creator. Select Odroid C2 LibreELEC-Odorid_C2.arm-8.95.001.img.gz and Write it.
Last try: Checking file system... |
It's very strange
It's very strange
Thats sadly not easily fixable without heavy Kodi patching and starting fixing the known very broken kernel codebase for AMLogic 3.14.
We have decided to not do that for K18 because the new kernel codebase is already at the corner and properly fixing the old one takes too much efforts that are basically wasted after K18 (the old way AML Kernel 3.14 is doing things is getting completely removed for K19). There is also a news article about it Development Update – LibreELEC .
Understood and appreciate the honest info. I'll just have to skip LE9 then on my WP2 as this is a deal breaker for my setup (Optical out to my receiver only), I can get by on 8.2.5 until the mainline kernel versions are hopefully stable.
Hi!. Another try. I install LE8.2.5 in a SDCard. Then I go to ".update" directory and wget last Libreelec C2 8.95.001. (This will dismiss problems with burn the IMG).
When restart It do the update of kernel and system. After reboot... Only show the logo and the version but not start KODI splash screen.
I have: rev0.2 20160226 version
Could you make an photo of the output?
Hi!. This is the state when insert fresh LE 8.95.001 for Odroid C2.
I try LE reborn remix and same result.
I try coreelec and it works!.
I'm going to be crazy!!!
Hmm just to clarify, installing 8.2 works, updating from 8.2->9.0 shows the same problem?
Yes. If I install 8.2 0 problems. Fresh install of LE9.0 hangs on first boot. Download into .update folder LE 9.0 hangs in first boot (update kernel and system ok, but on reboot hangs in logo).
You tried to update an existing build or you created a fresh sdcard with my build? You can't update a vanilla LE 9 build to mine.
Always fresh install. Format SD card and write img. Always hangs in first boot.
I try update if the problem were in flash img program but I can dismiss it.
Can be the problem be using arm vs aarch?
I dont know but if only happend to me its very strange. I have other boards so dont worry.
Thanks!!!
Display MoreAlways fresh install. Format SD card and write img. Always hangs in first boot.
Thanks!!!
Updating from a CE build failed too? It should not matter what arch you used before if you create a fresh sd
CE is coreelec?. I dont try to update from this version only install it and I have no problems.
So if I am the only with problems with OdroidC2 dont worry. I have more boards:
RPi2
Orange Pi plus 2e
Rock64
Thanks for your support!!!
Display MoreCE is coreelec?. I dont try to update from this version only install it and I have no problems.
RPi2
Orange Pi plus 2e
Rock64
Yes CE = CoreELEC so you could give it a try and see if the update fails too. Do you have any eMMC stuff installed?
Tomorrow I'll try and tell you the result. I dont have eMMC.
Hi!. It can't be update from coreelec to libreelec 9.0.
After extract the gz file it say: Missing (source) kernel or SYSTEM
Arggggg!
Have you tried to update with a tar file? Pretty strange all in all
I cant see tar file for LE 9.0.
So, dont worry. I can use other boards. My odroid C2 have a glinch, jajajaja.
Thanks for all your support
Installed noobs on a new memory card and an the basic libreelec install. Then upgraded it to 8.95.1
I then went to configure everything and noticed that Aeon Nox skin is missing along with some others.
My family really likes the Aeon Nox skin. How to get the skin?
