Is there anyway to test builds without having to backup and restore current install?
Like a live USB running these builds?
You can install LE to a USB drive.
ah good idea!
Display MoreThat's good news. You are the first one who reported a working HDR on older LSPCON hardware. It looks like that NUC has MegaChips MCDP2800BC LSPCON.
I uploaded an updated image.
- Linux kernel 5.12-rc4
- Kodi e04f7d6
Everything else is identical to a build from post #494.
Just tested it and HDR still works
However 'allow passthrough' doesn't seem to work with this build. I can turn it on but but missing all the options like DTS, Dolby etc to turn it on/off. Didn't had an issue with the 1st build I tested. And when I restore my backup which I made from the first build it does work again. And I'm still on the same build version (*32b3089). I take it it shouldn't be an issue to restore my backup, right?
btw thanks for you help again.
Can anybody post the link to the latest build based on Kodi matrix? I accedentally deleted the file. The link in this forum is dead.
you means this one ? :
P.S.
please, don't hijack threads with another theme
I remember that if you need to set the options for the DTS, Dolby Digital, etc you need to turn on Advanced View. Perhaps you're still using Basic settings and then they are not visible ?
- Kodi e04f7d6
NUC6AYH : No-go for HDR.
NUC7i3BN : Works with HDR (on the previous build you posted about roughly a week or two ago)
I mean the link to the latest HDR build based on kodi matrix.
That's interesting.
According to Intel's support pages for those NUCs they use the same MCDP2800 LSPCON chip.
Can you retest NUC6AYH with the build from post #502?
Also note that there is an issue with those builds. If you turn the TV off and then on (while the NUC is connected and working) - HDR will stop working until Kodi is restarted (maybe a bug in EDID parser code).
You are right.
Apologies! I've been upgrading several clients and forgot to turn it back on this machine.
- Kodi e04f7d6
This build has HDR working on my NUC7i5BNK and it looks great. However, the screen seems to go black intermittently for a few seconds and then the picture comes back on. This seems to happen frequently whilst tinkering with the settings in add-ons (not messing with picture settings) but also happens when playing video, albeit less frequently but, still once or twice at least every minute. I'm not sure if this is a known issue or not.
Does this happen with all video modes or only with 4K?
Thanks for the quick response. I decided to do some troubleshooting on the hardware side of things and it would appear that it "may" have been the HDMI cable that was the problem as I'm using another one just now and the issue has not yet re-occurred after playing a 4k video for about 6 minutes now. Strange, as the HDMI cable I was using works fine with other devices and there was no issue with it on previous build I was using. I'll report back if the issue crops up again but hopefully it's now resolved. The 4k HDR looks fantastic btw; nice work!
Update: The problem has indeed re-occurred, I'm afraid. I've tinkered with the display settings and the intermittent blanking of the screen does not seem to occur at all if I reduce the display to 1080p in the Kodi's display settings. If the display settings are set to 4k then the intermittant blanking happens even when not playing video, it happens when navigating Kodi's menus too. If I play a 1080p video though it does not occur, even if Kodi's display settings are set to 2160p as evidently it reduces the the resolution to match the video. Definitely seems to be an issue with displaying in 4k.
Try to test with a short (< 2m) known good cable connected directly to a TV. Intermittent blanking in 4K modes could be caused by a bad or too-long cable.
Looks like I ran into the NUC7PJYH bios update disaster 0058/0059 Will no long boot any form of Linux and you cant roll back the update. Another win from Intel. Don't update if you have one of these
In theory it should be possible with a Flashrom utility under DOS as long as somebody provides a bios dump from the same NUC.
That's interesting.
I think the 6 series CPU dont support HDR at all. Not even in Windows. I think I saw a Intel article that said Gemini Lake/Kaby Lake and newer will support HDR.
NUC6AYH has HDMI 2.0 port (MCDP2800 LSPCON), J3455 Apollo Lake SoC with Gen9 Graphics. It should be capable to support HDR in Linux.
Windows HDR support is irrelevant, Gemini Lake also doesn't support HDR in Windows.
