Bit of advice please lads did any of you invest in a hdmi 2.0 lead? If so was there any improvement on the 4K,my tv registers uhd through the supplied hdmi with my minimx and looks pretty awesome I'm just wondering if I actually need to buy a 2.0 or not?
Cheers
Gaz
[SOLVED] 4k TV display capabilities
Pelican -
August 21, 2016 at 11:36 AM -
@gazrbo I'm not sure where you got "the latest 4K tar update" from as it's been deleted from server some time ago but you may want to try this build: LibreELEC-S905.aarch64-7.0-devel-20160830160706-r23311-g51fe9ae.img.gzkszaq could you point me in the right direction for nand zip of the above please
kszaq could you point me in the right direction for nand zip of the above pleaseThere is no NAND zip for it. You can install .006 to internal memory, then download .img.gz to Update folder (instructions here: HOW TO:Update LibreELEC - LibreELEC).
kszaq thanks installed great
One thing that doesn't work as I was coming from a screwed nand is the remote,my question is I have a bootable libreelec sd which the remote works on can I extract the remote.conf from ssh into that? Or does anyone know where I could grab it from by any chance? It's the minimxiii -
Cheers
GazI think my MiniMX came with a 2.0 port, so I assume it included a 2.0 lead. But I don't have a 4k tv to test
I assumed so too but I went ahead and bought one anyway and seen a noticeable difference
