Remote does not work in 8.90.006
  • With 8.90.006 my remote doesn't work as it did until 8.90.005. Most of the keys are working correctly, but the key for the context menu brings up a message about "No PVR-Addon activated".
    I use a Logitech Harmony 600 and I never changed the settings since about 3 years. So there might be a change in LE 8.90.006?
    This is what I found in the debug log:
    15:35:13.799 T:140619617347328 DEBUG: LIRC: - NEW 16d 0 KEY_EPG devinput (KEY_EPG)
    15:35:13.805 T:140619625744512 DEBUG: HandleKey: two (0x32) pressed, action is ActivateWindow(TVGuide)
    Does it mean that the setting for key 16d has changed?
    Edited once, last by wwessel (October 11, 2018 at 2:45 PM).
    Please don't ask for support via news articles. Create your own thread in the correct forum section.
    Also, always provide a full, uncut kodi.log file. Just 2 lines is often not enough to pinpoint the source of a problem.
  • What device?
  • 15:35:13.799 T:140619617347328 DEBUG: LIRC: - NEW 16d 0 KEY_EPG devinput (KEY_EPG)
    Yes, this was a fix in kodi. KEY_EPG should bring up the EPG / TV guide, previously it was mapped to the "title" action KEY_EPG is wrongly mapped to title instead of guide · xbmc/xbmc@5e3e056 · GitHub
    You have to change your remote.xml if you want to map the EPG button to bring up the context menu.
