deco information: ferguson ariva 4k combo s905 1gb / 8gb tuner dvb s-s2 avl2011 dvb t-t2 avl6762 (I only need dvb S s2 working, dvbt isnt important for me).
I just need tvheadend and dvb-s to work, I have tried different versions and different dtb.img armbian coreelec alexelec ....
the best result is with libreelec 8.2.4 weteek dvb test2 and the dtb of k1plus.
the system starts successfully
ethernet works / wifi dont
detects the dvb built-in as avl6862 on all cards (presumably 6211 + 6762)
with the own dtb from android (5.1 kernel 3.14.29 gcc linaro) the system doesnt boot i try to modify k1plus.dtb severals times my self without any succes(i dont have idea what i was doing) sometimes boot succed but dont detect dvb , mostly dont boot.
I do not know what else to try, I would need your help.
dmesg | grep dvb
Display Spoiler
[ 19.843813@0] aml_dvb_init: aml dvb init
[ 19.844034@0] aml_dvb_probe: probe amlogic dvb driver
[ 19.844055@0] aml_dvb_probe: dmx rst ctl = ffffffc020b96ec0
[ 19.844063@0] aml_dvb_probe: asyncfifo rst ctl = ffffffc020b96e40
[ 19.844070@0] aml_dvb_probe: ahbarb0 rst ctl = ffffffc020b96dc0
[ 19.844077@0] aml_dvb_probe: uparsertop rst ctl = ffffffc020b96d40
[ 19.844087@0] aml_dvb_probe: ts0: parallel
[ 19.844164@0] aml_dvb_probe: ts0_control: 0x0
[ 19.844173@0] dvbdev: DVB: registering new adapter (amlogic-dvb)
[ 19.844176@0] aml_dvb_probe: Registered adpter: amlogic-dvb
[ 19.888790@1] aml_dvb_dmx_init: demux0
[ 19.912758@1] aml_dvb_dmx_init: demux1
[ 19.913367@1] aml_dvb_dmx_init: demux2
[ 19.913485@1] aml_dvb_asyncfifo_init: af:0 irq:51
[ 19.913544@1] aml_dvb_asyncfifo_init: af:1 irq:57
[ 25.010186@1] amlogic-dvb dvb.50: DVB: registering adapter 0 frontend 0 (Availink avl6862)...
[ 35.401731@1] amlogic-dvb dvb.50: DVB: adapter 0 frontend 0 frequency 0 out of range (174000000..862000000)
dmesg after tvheadend search
Display Spoiler
[ 35.176730@1] fb: current vmode=1080p60hz, cmd: 0x10000
[ 35.241218@0] fb: osd[0] enable: 1 (kodi.bin)
[ 35.301512@3] i2c i2c-1: avl6862 patch ver 2.0 build 20544
[ 35.407618@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 35.407632@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 35.407684@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 35.407691@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 35.408249@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 35.408265@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 36.435131@1] i2c i2c-1: Load avl6862 firmware patch for DVB-S/S2 size=44000
[ 39.910765@0] aml_snd_card: audio speaker off
[ 40.646409@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.646456@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.646542@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.646573@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.646657@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.646686@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.646777@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.646808@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.646892@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.646922@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.647005@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.647035@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.647351@1] i2c i2c-1: avl6862: failed to enter DVBSx mode
[ 40.665130@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.665154@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.665217@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.665233@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.665294@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.665309@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.665375@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.665390@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.665451@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.665466@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.665528@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 40.665542@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 40.665838@1] i2c i2c-1: avl6862: failed to enter DVBSx mode
[ 81.665978@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 81.666005@0] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 81.666070@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 81.666085@0] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 81.666147@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 81.666162@0] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 81.666228@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 81.666244@0] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 81.666305@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 81.666320@0] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 81.666382@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[ 81.666397@0] i2c i2c-1: token 1, master_no(1) 300K addr 0x7a
[ 81.666689@0] i2c i2c-1: avl6862: failed to enter DVBSx mode
lsmod
Display Spoiler
sha1_generic 2196 0
bnep 13775 2
8021q 19119 0
r848a 34282 1
avl6862 252922 1
dhd 745701 0
btsdio 4458 0
bluetooth 337611 7 bnep,btsdio
cfg80211 365310 1 dhd
6lowpan_iphc 10351 1 bluetooth
mali 230895 5
aml_fe 4946 0
aml 89804 2 aml_fe
dvb_core 102042 2 aml,aml_fe
wifi_dummy 806 0
amlvideodri 12578 0
videobuf_res 5386 1 amlvideodri
videobuf_core 16475 2 amlvideodri,videobuf_res
videodev 148677 1 amlvideodri
media 25055 2 videodev,dvb_core
dwc_otg 231967 0
fbcon 37495 0
bitblit 4484 1 fbcon
softcursor 1184 1 bitblit
font 7287 1 fbcon
thanks , and sorry my english.
