Could the sound quality of music improve without volume control?
  • Thanks a lot to the team of Libreelec for this great tool!
    I am happy with the quality of the music from flac files playing through my avr by hdmi/optical.
    But the sound is even better when the music is playing using libreelec as upnp server. Maybe kodi needs to process pcm info before sending to hdmi/optical to allow volume control -maybe some other features- that could be degrade slightly the sound quality.
    How to volume control could be bypassed to get original pcm signal by hdmi/optical?
    (S912 - Minix U9 - Libreelec 8.2.4.1)
    Edited once, last by gercabace (September 1, 2018 at 3:56 PM).
  • Only Passthrough Audio can bypass Kodi's volume control, PCM cannot I believe.
    I would also make sure these Kodi Settings > System > Audio options are disabled first:
    Number of Channels > whatever you Sound equiptment supports. SPDIF only supports 2.0 LPCM channels.
    Output configuration > Best Match
    Maintain Original Volume on Downmix > OFF
    Boost center channel when downmixing > 0DB
    Here is a OSMC Vero 4K thread that will interest you regarding AMLogic S9xx Linux & FLAC 24bit:
    Can Vero do bit-perfect playback? - Vero 4K / Vero 4K + - OSMC Forums
    The AMLogic Linux Kernel audio mods @graham8 talks about over there are also in the AML S9xx LE 8.2.5 releases found here:
    LE Google Drive Folder
    I do not know enough minute detail about Kodi audio to be of any further help.
  • I have updated to LE 8.2.5 and change some of those settings:
    - Number of Channels > 2 (unchanged)
    - Output configuration > Best Match (unchanged)
    - Maintain Original Volume on Downmix > OFF (changed from ON)
    - Booost center channel when downmixing > 0DB (changed from 10dB)
    and ... it works!! - Now, I cannot discern between playing by upnp and hdmi/optical.
    Many thanks for your help!
