LibreELEC 8.x images for additional dvb drivers
  • The error says that the storage Path is not found - this is due the LiveBoot. You could do it manually. Just create dvb-drivers.txt in downloads.
    In the dvb-drivers.txt needs to be one of this.
    1. 4.4.7-tbs
    2. 4.4.7-tbs-dvbc
    3. 4.4.7-crazycat
    4. 4.4.7-ljalves-cc
    5. 4.4.7-media_build
    But you have to look that you write this in this file without ANY space character or line ending.
  • Thanks CvH for the help.
    What I tried did not work, so I will wait a little while until the repo settles down and do a fresh install at that time.
    I have a query ....... if I install the official TBS drives at some point, but later I want to try the llajves drivers will that be possible using the same DVB-Driver interface or would it need to be done manually?
    Thank you and the other devs for your work on LE.
  • I have a query ....... if I install the official TBS drives at some point, but later I want to try the llajves drivers will that be possible using the same DVB-Driver interface or would it need to be done manually?
    You just need to click on an driver in the addon -> reboot and you have everything ready.
    VDR didn't care and at Tvheadend you need to redo the hardware selection at dvb inputs windows due that the name of the devices have been changed.
  • hello CVH
    I have a question about the latest version LE (Generic.x86_64-6.95.1-dvb-drivers-1.0.1.tar)
    Is this version LE (media_build) contains uvc drivers ? ...
    I think you know why :-)..... can supplement docker help installations needed several programs
    If so, try to play with the program docker .... although I'm not too good at linux
    regards!
  • Unfortunately not
    lsusb
    Bus 001 Device 008: ID 048d:9005 Integrated Technology Express, Inc.
    Bus 001 Device 006: ID 046d:c52b Logitech, Inc. Unifying Receiver
    Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
    Bus 001 Device 009: ID 046d:0825 Logitech, Inc. Webcam C270
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 004 Device 003: ID 1241:e000 Belkin
    Bus 004 Device 002: ID 19c2:6a11 Futuba MDM166A Fluorescent Display
    Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 003 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
    Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    lsmod
    Module Size Used by
    8021q 15393 0
    nvidia 11324401 40
    fuse 65074 3
    snd_hda_codec_hdmi 31862 4
    rc_it913x_v2 1326 0
    it913x 3817 1
    af9033 25450 1
    dvb_usb_af9035 16775 0
    dvb_usb_v2 11931 1 dvb_usb_af9035
    snd_usb_audio 117059 0
    dvb_core 72279 1 dvb_usb_v2
    rc_core 14638 4 rc_it913x_v2,dvb_usb_v2,dvb_usb_af9035
    snd_usbmidi_lib 17142 1 snd_usb_audio
    snd_rawmidi 14313 1 snd_usbmidi_lib
    snd_hda_codec_realtek 50604 1
    snd_hda_codec_generic 43477 1 snd_hda_codec_realtek
    snd_hda_intel 20100 1
    snd_hda_codec 70140 4 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel
    snd_hda_core 28290 5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
    snd_hwdep 4819 2 snd_usb_audio,snd_hda_codec
    asus_atk0110 8506 0
    1. 4.4.7-tbs
    2. 4.4.7-tbs-dvbc
    3. 4.4.7-crazycat
    4. 4.4.7-ljalves-cc
    I just want to report back after my clean LE-installation (of this 1.01 customimage). All went fine but I got the same errormessage as JohnBoyz, the workaround that CvH pasted here did the trick for me (the .txt file was missing).
    I now have everything up and running again. Smooth installation and my
    TBS5680 (usb) worked instantly after installing the Crazycat driver :D
  • Hello guys.
    Great job.
    I've been trying to get a TBS5220 Cable USB tuner working ina Raspberry Pi two following a thread at openelec forum.
    Still in OpenElec I did manage to have the USB tuner recognized usin ljalves .tar file to update but after that "small victory" I can't tune any DVB-C channel.
    It's not a TVH issue since, with the same setup, I've manage to tune DVB-C channels with another USB tuner (Geniatech T230).
    Do you plan to also support Raspberry Pi2 for LibreElec 7.0 with this great way to change drivers?
    Thank you.
    ezlmf
    Edited once, last by ezlmf ().
  • Do you plan to also support Raspberry Pi2 for LibreElec 7.0 with this great way to change drivers?
    At the moment a lot stuff is hardcoded (it is a bit effort to build an RPi image because I have to change a lot) - I was a bit in time problems due the release date of LE.
    So I wanted at first let you try something and find possible bugs and if its stable port it to RPi. Later I do the code better that it can easily ported to every platform :)
  • You just need to click on an driver in the addon -> reboot and you have everything ready.
    Thanks. ;)
  • At the moment a lot stuff is hardcoded (it is a bit effort to build an RPi image because I have to change a lot) - I was a bit in time problems due the release date of LE.
    Thank you for you time and effort.
    For the first time with LibreElec update to OpenElec - I had a x64 computer with TBS5220 doing it's job and tuning all channels :cool:
    One day I'm sure it will work with RPi2/3.
    ezlmf
    Edited once, last by CvH ().
  • Is there any chance the Rpi build will support the TBS5590? After buying this USB tuner I realized the linux support from TBS is pretty much useless, especially for ARM devices.
  • Are you sure that it is a TBS 5590? Because the TBS website doesn't know this card.
    Could he perhaps mean the TBS5990?
    Did you see we got it up and working on here  CvH
    Not sure but they just gave up after they got basic functionality, still won't do 1080P ...
