I installed the image onto a 32gb micro SD using Rufus,
powered down the box
inserted Micro SD into slot on box
held the reset button down and powered it on
The R-Box Pro screen displays and just stays there.
What am I doing wrong?
Exactly which image would that be? Your R-Box Pro seems to be a S912 device.
Using 8.2.4.1
Okay. switched around and used a USB port since the micro SD port isn't working for the sideload.
I'm at the android recovery screen and can't seem to figure which to use.
Menu says:
Reboot system now
Reboot to bootloader
apply update from EXT
apply update from cache
apply update from ABD
wipe data/factory reset
wipe cache partition
mount/system
view recovery logs
power off
What is ABD?
I failed to note at the bottom of the screen it says
Api: 3
Recovery is listening abd sideload...
Waiting abd sideload command...
E: cannot load volume /misc!
Apparently from what I ready from the last release saying that a new dbt wasn't need.
I was using a micro SD USB adapter and trying all the dbt files and it would bring me up to the android recovery screen.
so I pulled out the micro SD and shoved it in the card slot on the box, rebooted and Libre ELEC loaded up.
Only issue now is I do not have any type of remote control or usb mouse to get through the setup.
The DBT file I used was gxm_kvim2.dtb
Got the remote to work.
Copy and replaced the Remote.conf file with this one:
It matches the remote that came with my R-BOX Pro so I figured I give a try and Viola. works enough to get through the setup menu.
I'll try and get some free time to play with LibreELEC later on and update.
The micro SD card I am using if it matters is a UNIREX 32gb. supposedly with a 50mb max speed. Hopefully it doesn't cause me problems with playback.
