Hi, I'm first time user of Minix U9 with LibreELEC.
Taking SMB defaults when copying files from Win7-64 PC over CAT6 LAN to USB3 attached HDD on Minix U9 LibreELEC, I'm getting a file transfer rate of only 3 kbytes/s.
For comparison, when copying over same CAT6 LAN from Win7-64 PC to:
- old WDTV copying to same USB3 attached HDD I get 10 kbytes/s, or
- ASUS router's Network-attached USB3 HDD I get 22 kbytes/s (that was from PC's SATA1 drive, just got 80 kbytes/s copying from USB3 HDD on PC to ASUS router's Network-attached USB3 HDD)
Is it possible to change any LibreELEC SMB settings to get faster transfer?
Thanks for your help. Steve
PS I'm OK to make settings in an smb.config file or on a command line setting up an SMB drive, if that's what it takes.
