What is difference between 4.x and Leia 18 based builds in download section (balbes 155 based). I have nexbox s905x andriod tv box which one is suitable for me (arch or arm based) Where is device tree also. I m newbie any help. Thanks in advance.
Need help?
Michaelbates -
May 3, 2018 at 2:57 PM -
If I were you, I would forget about Leia for the moment, they are currently alpha
Once you get a working device, & a bit more experienced, then try Leia.
So, if you go here, [INDEX] LibreELEC community builds for Amlogic
Choose a Krypton build from [8.2.3.1] LibreELEC 8.2 for S905/S905X I know it says discontinued
Read the how to [HOWTO + FAQ] Install community builds on S905/S905D/S905W/S905X/S912 device
then download the imgz file & the device tree which is based on the RAM size & LAN speed
Burn image to microsd or usb using etcher or rufus copy the device tree to the root, rename it to dtb.img
Insert into device reboot holding reset button on device, after a few seconds it should reboot to libreelec, you will probably find the remote doesn't work, so use a keyboard
Set ssh to on,
to get the remote working, go to the thread remote.conf repository
if there isn't a remote there create your own from Create remote.conf from scratch
not unless you plan on being tester, then just stick to 8.2 releases from kszaq. only advantage of le9 is netflix/amazon addon support. i have a couple of s905x boxes that runs perfect via 8.2 installed on internal. primay use is to play videos via local network.
