[8.2.4.1] LibreELEC Kodi Krypton - S905 & S912 devices
  • You can see how you get on with LibreELEC-AMLGX.arm-9.80.9-box.img.gz .. If you stick to 1080p content it should be quite usable, but 4K is still a bit hit/miss and no HDR or HEVC support (S905X3 can s/w decode HEVC to 1080p). You need to edit the dtb name in extlinux.conf to match the device-tree file you choose, there is an experimental one for X96-Air 2G/4G devices.
    Thanks for your help.
    I'm looking for update this version to a new one.
    Which stable version do you guys recommend to update Mecool Pro III S912?
    Thank you in advance
  • Which stable version do you guys recommend to update Mecool Pro III S912?
    I use CoreELEC 9.2.5 with Kodi 18.9 on this device. I use a minisatip service for forwarding DVB-T channels and ffmpeg together with sshfs for forwarding the stream from a surveillance camera. All this is forwarded to the LibreELEC server located in another town. Mecool KIII Pro also, like any other multimedia client, receives all TV channels, multimedia content and storage space from the server, also allows me to remotely configure the devices on this home network via VPN. Everything works very well.
    The LibreELEC AMLGX 10.0 versions for this device are not yet mature but the expectations are good.
    Edited 2 times, last by elonesna ().
  • Hy please help.
    I should grant it in a menu routerben being the achievement of pendrive user:password-away an achievement.
    smb or FTP.
    ActivateWindow(Videos,smb://192.168.1.1/directory/directory/,return)
    2 sharing mistakes are mistakes so.
    ActivateWindow(Videos,smb://user:[email protected]/directory/directory/,return)
    passwords.xml:
    <passwords>
    <path>
    <path pathversion="1">smb://192.168.1.1/directory/directory/</path>
    <to pathversion="1">smb://user:[email protected]/directory/directory/</to>
    </path>
    </passwords>
    source.xml
    <source>
    <name>vid</name>
    <path pathversion="1">smb://bla_bla/directory/directory/</path>
    <allowsharing>true</allowsharing>
    </source>
    Thanks help.
