Hi everyone,
Seeking some help. I have a fresh (1st) install of LibreELEC onto a MicroSD and using to boot up in a Minix U1.
The version is LibreELEC-S905.arm-8.90.4.img
It works great! I'm plugged it all in away i went with watching all of the movies. But i recently tried to use the Analog Headphone jack and it doesn't appear to work.
I'm not too familiar with the ins and outs of LibreElec so hoping some one can help.
I've tried changing the audio output (not sure if this will help) but no change.
The minix is currently using HDMI.
Not sure if it has something to do with the device tree. As far as i was aware, since i was doing a 1st install i didn't have to do anything with the device tree.
i know there was a thread way back talking about a 8.0.0X build that may have resolved the issue but i would have thought then having the latest build it would have included the fix.
the intention was to use the analog jack and connect it to a 3.5mm jack bluetooth dongle to allow me to use bluetooth headphones.
Any ideas?
Quang
