Hello, just did a pull and I can't compile my Rockchip image anymore.
BUILD libtool (host)
TOOLCHAIN autotools
AUTORECONF libtool
autoreconf: Entering directory `/home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/libtool-2.4.6'
autoreconf: configure.ac: not using Gettext
autoreconf: running: /home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/toolchain/bin/aclocal -I /home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/toolchain/armv7ve-libreelec-linux-gnueabi/sysroot/usr/share/aclocal -I /home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/toolchain/armv7ve-libreelec-linux-gnueabi/sysroot/usr/share/aclocal --force -I m4
autoreconf: configure.ac: tracing
autoreconf: running: /home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/toolchain/bin/libtoolize --copy --force --ltdl
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, 'build-aux'.
libtoolize: copying file 'build-aux/compile'
libtoolize: copying file 'build-aux/config.guess'
libtoolize: copying file 'build-aux/config.sub'
libtoolize: copying file 'build-aux/depcomp'
libtoolize: copying file 'build-aux/install-sh'
libtoolize: copying file 'build-aux/missing'
libtoolize: copying file 'build-aux/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'm4'.
libtoolize: copying file 'm4/libtool.m4'
libtoolize: You should add the contents of 'm4/libtool.m4' to 'aclocal.m4'.
libtoolize: copying file 'm4/ltargz.m4'
libtoolize: You should add the contents of 'm4/ltargz.m4' to 'aclocal.m4'.
libtoolize: copying file 'm4/ltdl.m4'
libtoolize: You should add the contents of 'm4/ltdl.m4' to 'aclocal.m4'.
libtoolize: copying file 'm4/ltoptions.m4'
libtoolize: You should add the contents of 'm4/ltoptions.m4' to 'aclocal.m4'.
libtoolize: copying file 'm4/ltsugar.m4'
libtoolize: You should add the contents of 'm4/ltsugar.m4' to 'aclocal.m4'.
libtoolize: copying file 'm4/ltversion.m4'
libtoolize: copying file 'm4/lt~obsolete.m4'
libtoolize: You should add the contents of 'm4/lt~obsolete.m4' to 'aclocal.m4'.
libtoolize: putting libltdl files in LT_CONFIG_LTDL_DIR, 'libltdl'.
libtoolize: copying file 'libltdl/COPYING.LIB'
libtoolize: copying file 'libltdl/Makefile.am'
libtoolize: copying file 'libltdl/README'
libtoolize: copying file 'libltdl/configure.ac'
libtoolize: copying file 'libltdl/aclocal.m4'
libtoolize: copying file 'libltdl/Makefile.in'
libtoolize: copying file 'libltdl/config-h.in'
libtoolize: copying file 'libltdl/configure'
libtoolize: copying file 'libltdl/libltdl/lt__alloc.h'
libtoolize: copying file 'libltdl/libltdl/lt__argz_.h'
libtoolize: copying file 'libltdl/libltdl/lt__dirent.h'
libtoolize: copying file 'libltdl/libltdl/lt__glibc.h'
libtoolize: copying file 'libltdl/libltdl/lt__private.h'
libtoolize: copying file 'libltdl/libltdl/lt__strl.h'
libtoolize: copying file 'libltdl/libltdl/lt_dlloader.h'
libtoolize: copying file 'libltdl/libltdl/lt_error.h'
libtoolize: copying file 'libltdl/libltdl/lt_system.h'
libtoolize: copying file 'libltdl/libltdl/slist.h'
libtoolize: copying file 'libltdl/loaders/dld_link.c'
libtoolize: copying file 'libltdl/loaders/dlopen.c'
libtoolize: copying file 'libltdl/loaders/dyld.c'
libtoolize: copying file 'libltdl/loaders/load_add_on.c'
libtoolize: copying file 'libltdl/loaders/loadlibrary.c'
libtoolize: copying file 'libltdl/loaders/preopen.c'
libtoolize: copying file 'libltdl/loaders/shl_load.c'
libtoolize: copying file 'libltdl/lt__alloc.c'
libtoolize: copying file 'libltdl/lt__argz.c'
libtoolize: copying file 'libltdl/lt__dirent.c'
libtoolize: copying file 'libltdl/lt__strl.c'
libtoolize: copying file 'libltdl/lt_dlloader.c'
libtoolize: copying file 'libltdl/lt_error.c'
libtoolize: copying file 'libltdl/ltdl.c'
libtoolize: copying file 'libltdl/ltdl.h'
libtoolize: copying file 'libltdl/slist.c'
libtoolize: Remember to add 'LTDL_INIT' to configure.ac.
autoreconf: running: /home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/toolchain/bin/autoconf --include=/home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/toolchain/armv7ve-libreelec-linux-gnueabi/sysroot/usr/share/aclocal --force
autoreconf: running: /home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/toolchain/bin/autoheader --include=/home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/toolchain/armv7ve-libreelec-linux-gnueabi/sysroot/usr/share/aclocal --force
autoreconf: running: /home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/toolchain/bin/automake --add-missing --copy --force-missing
automake: error: cannot open < libltdl/ltdl.mk: No such file or directory
autoreconf: /home/harsszegi/rockchip/LibreELEC.tv/build.LibreELEC-Fireprime.arm-9.0-devel/toolchain/bin/automake failed with exit status: 1
Makefile:12: recipe for target 'image' failed
make: *** [image] Error 1
harsszegi@harsszegi:~/rockchip/LibreELEC.tv$
Display More
Any thoughts?
Thanks,
