Hi.
I have a 47lg860w-za tv and using a cubox-i4. Running Libreelec 8.2.3
I am frequently loosing the HDMI audio connection when i reboot kodi. The connection is ALSA:imx-hdmi-soc, GSM LG TV on HDMI. What is not to be found in settings-system-audio. Only the spdif and bluetooth are viseble but no hdmi.
I have found out when i change the hdmi input port on the tv and reboot kodi i can revert to the correct setting in system-audi. After that i have sound until next time i have to reboot than i need to make the same procedure again.
Is there a solution for this or maybe this is a common error you know already.
thanks Finn
